BevoZ06
I am in the planning stage of finally finishing off the interior of a detached garage that was originally built 19 years ago. I have pretty well decided to use plywood on the interior walls rather than drywall/sheetrock.
It has the 16' wide overhead door and a 3' walk-in door. I ran the electrical rough in when we first bought the property and have installed receptacles about every four feet around the perimeter. There are no windows, so I have ordered windows and the window installation will be the first step of finishing.
I need to do one wall at a time because I already have so much in the garage that I cannot clear more than one wall at a time to work on it. I will need to park two of our vehicles inside each night so I can't just clear everything from all the walls and move it all to the center at the same time.
I was planning to use 3/8" plywood because it's lighter and I will be doing it by myself. Plus I can work with wood much better than I can with sheetrock. When I install the plywood sheeting, should I glue them to the studs as well as using screws or will the screws be enough? I don't envision ever trying to heat or cool the garage, so I will not be insulating, if that matters.
Thanks for any suggestions. I haven't done any of this type of work since 1979 when I bought a house that was rough-framed and I finished it off. At that time I contracted out the drywall work, but this garage will be totally do-it-myself. As Toby Keith sings, "I ain't as good as I once was, but I'm as good once as I ever was." (Just a little slower now.)
Thanks for reading and for your helpful suggestions.
