1 3/16 wrench
sumner52000
Roxboro, NC
1 3/16" wrenches. Do they exist? I have multiple sets of wrenches but no 1 3/16". They go from 1 1/8" straight to 1 1/4". I do have some 1 3/16" sockets but can't ever remember using them. Any of you have a wrench and have you ever used it?
wafrederick
Holton,Mi
The socket is easy to find and the wrench can be hard to find.Craftsman has no 1 3/16 wrenches,has the sockets in shallow.I have one 1 3/16 wrench,a sk combo wrench.1 3/16 is used on older transfer cases for the fill and drain plugs.
dtt454
missouri
30 mm is more common, its close enough you can substitute it.
i have both 1 and 3/16 and 30 mm wrenches. and use them.
nine4gmc
Dallas
so there is no raised panel 1-3/16"? :sad:
cide1
I don't think it exists. I have every RP size I could find for sale in my collection, and I don't have a 1-3/16.
bobcatdan
Kaukauna,WI
1 3/16" is often skipped by sets, however most compaines do make them. Craftsman to my knowledge never did. 30mm is pretty much enterchangable. I never gave 1 3/16" much thought until I started at Deere. For the last 40 years, John Deeres have been held together with 1 3/16" head bolts.
Hammell
Canada
Catipillar b and c series excavators, cap for filling the hydrolic tank.. Probally 30mm but either or.
Bullitt427
I haven't ran across having to use 1 3/16" on a Deere. 1 5/16" on the blade pivot for 750C Series II Dozers.
Trying to use an SAE wrench on a metric fastener? Like the sprocket segments on the 750C? Those are 30mm bolts.
Josh
crewchief888
NW indiana
Josh
there seemed to be a lot of bolts on (mid-late 90's) hitachi built excavators that were 1 3/16
i even have 1/2" dr impact wobbles 1 3/16 & 1 5/16.
:beer:
swing motor/ gearbox bolts.
bobcatdan
Kaukauna,WI
I was an ag tech, the old Waterloo builts are full of 1 3/16". Newer 8000 series is all 30mm and 32mm. Other then a stray 444 here and there, never did much on the con eq.
Bullitt427
I haven't worked much on AG except 8XXX and 9XXX pull scraper tractors, almost all Yellow equipment for me.
Josh
jabberwoki
puyallup wa usa
Yep i have one too in Williams and yep it`s never been used even though i`ts an older wrench.
oldldh
Fairhope, AL
I got the 43 pc Craftsman Combo Wrench set for Christmas, and the set has a hole where the 1 3/16 should be...
Got to find one..."Holy Sheep Dip"!!!!
Tig Master
Where it snows
The RP is listed in the 73 catalog, but as mentioned probably not in any sets.
I have one in Proto.
jimexcursion
Maine
I used a socket that size on a motor mount bolt in a 1995 Kenworth T300. May have been metric. I can't recall but the 1 3/16" worked. Impact gun with a socket on 1 side and breaker bar with a socket on the other.
Rsigillito
Mower blade bolt that holds blades on exmark zero turn.
Been looking for an s-k raised panel for a while, haven't found one yet
Bigblue&Goldie
I needed one the other day to tighten a barrel nut on an AR15. I didn't want to buy one, and the jaws of my adjustable wrench were too wide, so I ended up buying a Knipex plier wrench to do the job. I'm glad I spent the money on the Knipex as they are awesome, and not on a wrench that I would likely never use again.
kenburkholz
Cleaver Brooks, boiler feed water storage tanks used this size on the door clamp nuts. In the boiler room, we used all different sizes of wrenches.1 3/16, 1 1/4, 1 5/16, 1 3/8, and on and on. When we couldn't find a size we needed we would just go look for a cheap Chinese set that had what we needed. We knew they would outlast us ,with the infrequent use they would get. They performed adequately. Ken.
