gfast
Mesa Az.
Re: what did you do in your garage today?
Sand blasted some more on my truck frame,getting it ready for some paint.
KNS Autosport
Montreal
Installed 4 tires on Acura CSX
Oil change and 4 tires on Subaru legacy
Plugs and Wires on Honda Accord
Welded exhaust Bracket on Honda Civic
Inspected Rear brake issue on Acura EL
JMartel
Seattle, WA
Bought some pegboard and started hanging up tools. Still got some left to go though.
Jawn
Stuck in traffic, GA
Replaced a throttle position sensor, then cleaned out the secondary air injection tube (was nearly completely clogged with a big fat carbon-cake).
This on a Saturn SL1.
(thank goodness for impact tools)
St. Albert, Alberta
Installed new boxes for upcoming reno. We put in something like 12 rectangle boxes, and four octogon boxes for lights. Still need three more rectangle boxes, another octo, and two 4" squar boxes for 220.
Feels good man.
santagary
Pagosa Springs, Colorado
Started a fire in the "all nighter" air tight stove, pet my cat and remounted my new:beer: left tail light and license plate bracket on my new project...my '46 Ford 1/2 ton.:beer: also had a scotch....Scoresby...three fingers and two cubes.
bobadame
Today and yesterday, installed 160' of air line in the shop. 80' of 1/2" copper and 80' of 1/2" black iron pipe. I've had the copper for years so I used it. Wouldn't do it at todays prices though. There are 12 places to plug into the system, 4 are dedicated for pneumatic machines, the rest are for smaller hand held tools. Had leak problems with some Chinese Homer Despot npt fittings. The threaded area was sort of hex shaped. Had to cut the pipe, replace the fittings and install unions. This cost an extra $20. and half a day of time.
Boyd Who
Manitoba
Started work on a transmission crossmember for my '27 Essex project.
henrysgarage
Carleton Place, ON, Canada
Changed the 4 steering column bushings on the tractor. Took the diff apart on the wagon to inspect the R&P and reseal the backing plates to axle flange and C clip eliminator housing, plus now rear shoes.
Mgraves235
Crossett, Arkansas
Got the last few pieces ordered that I need to put my welder back together.
Layed out my cuts on my '53 frame.
Rebuilt an old floor jack.
Flushed jack oil out of left eye.
sc3013
southern Indiana
Grand daughter came by today, huged my neck, asked if I would look at her ford ESCAPE. Oil and filter change, replace rear brakes, rotate tires, fix coolant leak, another hug and shes gone. It was great having her around the shop for a number of hours today.
Nick DL
Souderton, Pa.
Yesterday and today I finished installing the cabinets. I also got around to unpacking some of the boxes. It is starting to look better with some of the boxes gone. I still have a ton of things to do.
Sent from my Droid using Tapatalk
tcianci
Walpole, Ma
Scrubbed the epoxy floor in the garage after my brake plumbing project on my daughters 96 Olds. Put other stuff away and labled the drawers on my top box
KermitFrog
NW Florida
Worked on my daughter's car. Put on a new battery terminal, replaced the PCV hose.
Next I broke open a tool bag I haven't opened in around 17 years. I always thought Blackhawk was junk and I had a "cheap" set I bought back in 1986-87. The 1/4 ratchet was nearly frozen and would barely move. Pulled it apart and greased it up, this thing is now by far my most smooth acting 1/4 I own - VERY NICE! The rest of the set is pretty nice and surprisingly not too much is missing from the whole set. Everything was loose out of the case when I open the bag.
After that I cleaned up the mess.....got to keep what I have cleaned so far in my garage clean. Hopefully this week I will get pegboard up and the new box in (my dad is giving me his old box and I am getting my old box I had in high school back at the house......very cheap box, around 25 years old but in nice shape.
srmofo
SW ohio
Finally hung up the liftmaster 3800 on my second door. I had a buddy hanging my doors while I was finishing the roof and he positioned the torsion bar too far over, so first I had to unwind and reposition....which involved cutting some rod for winding bars...which meant I had to clear a path to workbench...and then locate the tools for cutting the bars. Ive only had it for over a year now, now I see why I procrastinating so much.
Started cleaning and organizing stuff....again. Im not sure how I manage to drag out every tool I own, but it seems to be a regular event for me.
Hauled a few things into the attic and a few things down from the attic
BCRacing7469
West Michigan
Swept leaves out of garage, since my wife insist on leaving it open. Arggghhh. Finally got the racecar put away om jackstands an covered up.
CRE Neal
I got my hydronic heat running and finished off the interior sheeting.....
TheManShopSD
South Dakota
-Hung up some more OSB on the interior walls of the shop.
-Watched the Packers dismantle the Raiders(not a fan, Bears game not on in my area)
-Played a game of HORSE with my 5 year old and whooped him. :)
-Hooked up the the Ol' Sony Receiver with 12" floor speakers. We're jammin' now
-Drank two Bud Selects
-Loved up my two girls(the dogs)
-Peed in the floor drain after 2nd beer
-Swept up the saw dust from cutting the OSB
-Called it a day and headed inside for frozen pizzas
drmarkr
Tucson
Built this mahogany fireplace mantel.....well, actually it was yesterday AND today.
Red Leader
Denver, CO
Started the 'preservation' work on my newly acquired vintage Craftsman tool chest:
Will try to do more tomorrow:thumbup:
Red Leader
Denver, CO
looks great, how did you do it? Soap and water, polish, buffing compound?
Thanks! I had some guitar polish swirl remover laying around that I haven't used in a long time, so started with that to clean up the surface, then I would strategically and carefully use fine steel wool on parts that seemed stained with some foreign substance, then polish again, then get the remaining stuff off with a razor blade. Using the razor blade was like operating on someone - it takes a steady hand! Then a final polish.
It took forever, but it worked pretty good!
It has a few minimal rust spots below and I'm hoping to tackle those once the rest is done. Again, minimal touch up for preservation. I want to keep the original finish, but I also want to take care of the rust as well.
Can't wait to see what it looks like when the whole thing is done:)
azjeeper
Chandler,AZ
Sanded down a cheap CL find, Snap on tool top road chest, and painted partial pieces. Looking good, Beautiful day here in AZ, Rain in store for the next couple of days,
BeachBum2012
So Cal
Last night I got started on cleaning out my girl's garage to make way for me moving in next month. She says I get carte blanch on the garage as long as I get her craft room build for her. Had to "explain" to her that I need to get the garage done first so that I have somewhere to build everything for the craft room. So far I think its working.
KermitFrog
NW Florida
Built a work table, not as heavy duty as what I see here but I don't need it to be. I still did the fata$$ test and it did great. (fata$$ test was me jumping up on it, if it broke it would have been a little more flimsy than I wanted - result was it didn't budge.)
LoRollinLS
tore down the front end of my truck to do winter cleaning and maintenance.... :p
Lippyp
Shropshire, UK
Opened the door, rummaged through one of the many many cardboard boxes in there trying to find my drill bits, sighed and gave up and bought a new set. I really need to find a day to get in there and start organising and unboxing after the move but the house takes priority right now until after christmas.
I did find a couple of pictures I took yesterday of my old single sectional concrete garage when we were all packed up for the move. Tidiest its been since we moved in!
Cars&Classic
Carmel, Indiana
Hung and organized another cabinet, (still getting moved in) moving in is the worst because you still cant find the right tool for the job! but the more I do the easyer it gets with less to trip over and more tools located for the next project:bounce:
zmotorsports
Northern Utah
I haven't been on the forum in a while but I have been building the wife and I a new toy in between paying jobs. This will replace our 1996 Jeep Grand Cherokee that we used to tow behind our coach and explore with.
This is my new daily driver and our Moab cruiser. I ought to start a build thread as I have been taking pictures along the way.
Mike.
Red Leader
Denver, CO
Damn thats a nice box, where did ya find it ? :thumbup:
oh yeah....stained some baseboards, hung the christmas lights and lawn ****
Absolutely Love that Box!! Very nice find.
Thanks guys! I got a tip from a local guy here who saw my garage build thread and knew I was doing a vintage Craftsman theme. He picked up a vintage Craftsman grinder and saw the box when he got it. To be honest, I saw the grinder on C/L and some other Craftsman tools but didn't go because they weren't 'necessities'. He kindly showed me this 'necessity':D
The guy has some other neat Craftsman stuff I may try and pick up.
-Dave
charged9250
Thanks guys. Here is one more. Total cost was $30!! Block was $20, bolts & paint $10, glass top free, wood stand free.
