I could use some help on setting up my manifold. I have tried calling and emailing Everhot Inc and only get an answering machine. I have emailed them as well as Pex Universe and no reply. They sent me the installation manual but nothing on how to purge or balance the manifold.
I poured my slab 2 weeks ago and have been pulling my hair out trying to get my system to flow right. I have a 6 port Everhot stainless steel manifold. I have 5 loops in the slab, the 6th port is for a future unit heater for the other part of my shop. With all 5 loops open I can only get about 0.1 GPM. I did find a video on Youtube by Uponor showing how to set theirs up so I used the same process and still no luck.
Here is what I have:
80 gallon hot water heater as my heat source
Grundfos Circulator Pump UPS15-58FRC w/internal flow check
Everhot 6-branch Stainless Steel manifold
5 loops in slab ranging in length from 225' - 250'
6th loop is for a future unit heater
Expansion tank from Lowes (set at 20PSI)
I have the pump mounted on top of the hot side of the water heater. The feed then goes up and across the rafters and back down to the manifold. On the return side I have my expansion tank, it then goes into a T and back down to the cold side of the water heater. On the other side of the T is my house water supply line for the system in which I have installed a black flow preventer. I have even cut 2 drain valves at the high point of the system to purge any air out. I have purge everything so many times I lost count. While I may get a little bit of air out it didn't seem to be enough to cause problems. The pump is putting out anywhere from 25 - 40 PSI. Someone told me that is really high but you would think if it is high I should be able to flow more then 0.1 GPM.
I hope what I described makes sense.
Any help or suggestions would greatly appreciated.
Thanks,
Dave
Thanks,
Dave
