Does such a thing exist?
I need something like this and I would rather not use adaptors.
Is that 1 and 1/8th of an inch..?? On a 1/4" drive...!!
That's on the high side for 1/2 drive, should be looking at 3/4 drive.![]()
I don't think you nessesarily need to go 3/4" drive at that point, but your getting pretty close. It's definely higher end of 1/2" drive category. Way too large for 1/4" drive tools for sure.
Not sure why anyone would want to use a 1/4" drive tool on a 1 1/8" socket???
No chance, unless you can find something custom. 1/4" tops out at 5/8" and 3/8" at 1". Now you may be able to find a single adaptor available to go from quarter to half instead of a stack but I can't think of of any off hand.
Measuring rolling torque like this IME is best done with a snap on torqometer and to get good resolution in the low inch pounds means a scale of 0-25 inch pounds, which only comes is 1/4 drive.
You can get that measurement range inside of 3/8"drive torque tools as well. You can use a 1/4 drive torque wrench, Amrmstrong, Proto, SO, MAC, and others offer these but seriously, you're going to have to use a few (at least a couple) adapter there. 3/8"male to1/4"female adapter into a 3/8"female to 1/2"male adapter into the socket. You only need to keep that pinion nut turning in a constant turn motion to measure your bearings preload on the torque wrench.
PN and pics?I think I have a 1" 1/4 drive socket.. I've never used it though.
PN and pics?
