Where do you drain your air tanks?
StaggeringGoat
Oregon
I have several smaller compressors that I use all hooked together and that means 5 tanks to drain. It wouldn't be cost effective to put an automatic drain on each one and pipe that somewhere.
The problem is when I let the water out of my tanks, I get a nice rusty puddle on my floor. I can't exactly put a bucket under it because the air pressure blows the water everywhere.
There must be some way to acomplish this task without making a mess on the floor. Anyone? Running a drain line outside for each tank just isn't feaseable....
machine_punk
Napa Valley, California
I suppose you could put some sort of oil drip tray down...maybe a big scotch pad to keep it from blasting all over? I guess I just decided to live the with rust stain on the floor.
buzz4041
South Texas
I got a valve piped out on mine and I wrap a towel around it so it soaks up the water. I just crack the valve a little and let the tank drain down. I do the same rag trick to all of my blow downs and main filters and air/filter regulators at each drop. My floor is epoxy so no stain :)
HAP
NE North Carolina
I've got mine tied to my sink drain. I made a 45* nozzle that is inserted to promote flow away from the sink. The sink simply drains out onto the grass. I also have a solenoid that is actuated by a mommentary button. So I just press the button intill there is no more visible moisture coming through the nylon drain line.
HAP
1948
IL WI border
make up a drain rail out of some steel tube and an NPT die. all into one drain to the outside, easy access. since they are tied together anyway.
JCQuick
Apopka Fla.
mine is next to the door so I have a hose on the drain and it sticks out the bottom of the garage door
Chris Adams
I have a cheap plastic tray, about 1.5 inches deep.
The sudden blast of air when my auto drain opens shifted it a couple times.
So I tossed some lead tire weights in the bottom, now it stays put. A few drops spray around it, but nothing worth worrying about.
It's all hidden under the tank bottom skirt anyway.
fr0mastaj
My drain valve setup is pretty close to the floor, so I just put a folded up shop rag directly underneath it. It absorbs all of the rusty water and nothing splashes around either - nice and clean concrete.
KCarGuy
50 miles outside Chicago, illinois
I have an Autodrain system that Has a Hose attached to it and goes outside behind my garage.
Every 30 minutes it opens up and blasts for 5 seconds.
Might scare a stray cat or 2 in the middle of the night...
paranoid56
San Diego, Ca
i just put a hose on it with a ball valve. makes it easy to drain to outside. also keeps the water out of the tank and in the hose.
darkzero
SoCal
+1
The ball valve makes it so much easier than having to reach under the tank.
With my old 20 gal compressor it didn't sit close to the door & the drain was close to the ground. I just used an old oven pan under it with an old shirt/rag in it. Open the valve & it drain right into the pan & the rag caught everything, no spraying onto the concrete.
rlitman
Long Island
When I read the thread title, the first thing that came to mind was:
Out the bottom.
But seriously, my compressor is in my garage loft. I have a long ****** in the bottom of the tank, a ball valve at the other end, with a drain valve under that. I then have a hose hanging from the drain valve, and I drain the water into a jar every few days.
Usually it's just a tablespoon or two, and the idea with the long pipe ******, is the water sits in there, and not in the tank.
I use the drain valve, because I can adjust the opening so I don't get a blast when I open the ball valve.
Jawn
Stuck in traffic, GA
Mine's a portable compressor with the vent-out-the-middle type of drain ****, so I just grab an already-cruddy shop rag when I reach down to open it... keeps rusty, oily, cold water off my hand and keeps the landlord's floor clean-ish. :p
Steevo
43.49600, -112.04300
I drain into a jug, using a hose. Then I pour it out under my neighbors car in his driveway. He's been looking for that leak for a year now.
