KrucksGarage
Hi folks,
Below I have copy and pasted some brainstorming from a microsoft word document I made recently. I've been trying to take into consideration all aspects to consider for my up and coming shop build. I plan to do all or a majority of the work myself with the help from friends and family with experience. I've been reading a ton of threads on here about builds and have learned a lot already with this resourse and others, but give me a little input on what you see below and let me know what I might want to add to the list. My shop is going to be 40' X 60' X 16'. I plan to build it somewhat in it's simplest form at first and then add what I can do without later on to be more affordable. My intent is for vehicle and other storage, metal fabrication, various vehicle projects, side work in the welding field, etc. Toying with the idea of building a mezzanine or loft on one end and going with three instead of four garage bay doors, but haven't decided. I intend to buy a set of plans this coming spring/summer, and start getting underway with permitting and dirtwork. For the most part the content below was taken from my personal notes I've been making. I printed it out and have gotten some material bids already and made other Q and A subpoints but this is my basic reference sheet. Let me know what you think.
40 x 60 x 16 GARAGE INFO WORKSHEET
PERMITTING:
When do I do this, do I need drawings first?
DRAWINGS / CONSULTATION WITH ARCHITECT:
Meet with architect, ask all questions below, take notes.
Purchase drawings to get started with material bids
Need to figure out the order of operations
DIRTWORK:
Excavating vegetation
Burning
Shooting grade
Ditching - drains, electrical, plumbing
Leveling for slab
Backfill
catch basin for sink
CONCRETE:
footing (6” thick X 18” wide)
stem wall (2’ hight X 8" thick)
slab (4” - 5")
Concrete Questions:
1) What are the best reinforcements / crack inhibitors?
Rebar, fiber/wire mesh, zip strips, saw cuts
2) What is the benefit of thicker slab (5”) $-->?
3) Do I need thicker concrete in area of mezzanine posts or lift?
4) what is the optimum spacing for rebar and what is the added cost
LUMBER:
Top and bottom plates (2X6’s)
wall studs (14’ – 2X6’s) 2' stem wall + 14' studs = 16' eve height
beams/headers over doors/windows
trusses
side and roof sheeting
bird blocks
trim – painted trim color of house
tyvek weatherization
Lumber Questions:
1) What is the cost/benefit exchange of cdx plywood vs. osb for sheeting (both for roof and side)
2) What is the cost/benefit exchange of hemfir to doug fir
3) How much extra cost involved for attic trusses and are they feasible to span this floor plan
4) Do I need specific additions to wall structure for mezzanine or loft attachment
GARAGE DOORS / WINDOWS:
Roll-up shop doors – 14’ height, 12’ width either 4 doors on 60’ side, or 3 doors with one bay for 2-story w/ mezzanine / loft
1 man door on house side of garage
1 man door on opposite side from house
Possible upper windows for natural light
Garage Door / Window Questions:
1) How feasible is it to add in windows later – cost$$?
2) How feasible is it to add second (lower) man door later
3) Is spacing of 3’ on ends and 2’ between doors for 4 garage bay doors on 60’ side feasible?
ELECTRICAL:
Run from existing transformer - ditch across
Power panel(s)
230V outlets (welder, compressor) – compressor switched near door?
120V outlets every 10 feet or to code
Lighting (interior: dome mercury, fluorescent….? Exterior: projectable/aimable halogen?)
Light switches at all doors, including man doors and all bay doors
Total load:
30A compressor
50A welders
Overhead lighting
Vehicle lift
Outside lighting (halogen)
Available breaker for heating
Hot water heater for sink
Electrical Questions:
1) What size panel(s) are required for this application?
2) Size of breakers for lift?
3) How much lighting per light circuit, are there fixtures that allow more per circuit?
4) What is the most cost effective form of lighting compared to lumens?
5) Can wiring for the lift be run in the overhead or do I need to run conduit in slab?
6) What is the best spacing between lights
SIDING:
Hardi to match the house
Siding Questions:
1) What are all other options, look decent?
2) What is the cost comparison between siding – longevity?
ROOFING:
Tar paper
Architectural composition roofing
Roofing Questions:
1) What is the cost breakdown between 30 – 40 – 50 year roofing?
PLUMBING:
Wash basin?
Hose bibs for exterior
Small hot water heater for sink
EXTERIOR:
Lighting
Hose bib(s)
Power outlets
Driveway slab?? ---$$
Gable end vents
Gutters/downspouts – painted trim color of house
Paint – same as house
HARDWARE:
Nails
Screws
Sheeting alignment clips
e-quake straps
end clips / lumber brackets
various garage door hardware
Other questions for the architect:
1) What is the simplest plan / cheapest route to achieve this floor plan to come as close to these results as I can. What are the varying options and what are the compromises to make it more affordable?
2) If I eventually want to run outdoor stairs to an upper mezzanine door, how will that effect the drawings / permitting
Things to think about or add to the shop in the long run:
(AKA things that can wait):
1) Insulation
2) Sheetrock
3) Heating system – propane, 230V --- options??
4) Air plumbing / manifolds / regulators
5) Lumber and various materials for mezzanine
6) Soundproof board for mezzanine
7) Vehicle lift
8) Utility sink and hot water heater
PERMITTING:
DIRTWORK:
Burning
Shooting grade
Leveling for slab
Backfill
CONCRETE:
slab (4” - 5")
Concrete Questions:
LUMBER:
trusses
bird blocks
Lumber Questions:
ELECTRICAL:
Power panel(s)
Total load:
30A compressor
50A welders
Overhead lighting
Vehicle lift
SIDING:
Siding Questions:
ROOFING:
Tar paper
Roofing Questions:
PLUMBING:
Wash basin?
EXTERIOR:
Lighting
Hose bib(s)
Power outlets
Gable end vents
HARDWARE:
Nails
Screws
e-quake straps
1) Insulation
2) Sheetrock
7) Vehicle lift
