marcello7x
- Joined
- Dec 22, 2011
- Messages
- 61
So im passing papers on my first house next month at some point, and im far more excited for the garage than the house itself. The house needs minor work, and elbow grease, but the garage needs quite a bit more.
First i need a new roof, simple enough. Wood below shingles should be ok, but we'll see when everything is pulled off. I may pull the old roof myself, then have a contractor put on the new stuff.
Secondly i need a new floor. The garage is a 4 car, with a loft[see avatar]. 2 bays at the bottom, 2 above with loft. Currently only one bay of the 4 are usable. The floor of the second floor is wood, and it has a ton of support 4x4's to support one bay, which then blocks off all the use of the bottom bays.
I would like to put a slab to support the second floor since i have more height there for a lift. Its more comfortable, with better access to the loft/mancave, and should heat better in the winter. As well as easier access to the house. Leaving the lower bays, which have no incline to climb[think of new england snowy winter] for the daily drivers.
How thick does the slab need to be. I read a minimum of 5" for the 2 post 10,000 lift. But since its not going directly over a hard surface does it need more? Also i know i need atleast a big "I" beam, but what else?
I also plan on radiant heating. How well will it heat both upper and lower levels. I mostly need the upper, but it would be nice to keep warm lower bays as well.
I will have a contractor come out and do most of the work to put in a new floor. But i will mostlikely remove the old.
