Need Air tool/Compressor Advice - Thanks
lineman88
Massachusetts
I own a Dewalt Compressor http://www.dewalt.com/tools/compressors-wheeled-portable---electric-d55146.aspx that says it produces 5.0 SCFM@90psi with a small 4.5 gal tank. I use it exclusively for nail guns. I'm looking to be able to just take lug nuts off to rotate tires. I have a cheap CM gun http://www.amazon.com/dp/B001PX35V2/?tag=atomicindus08-20 and some impact sockets and 3/8 hose but it won't remove even moderately tight nuts. The compressor is not cycling so I think it has enough air and its set at 90psi which the manual says. Any idea what's wrong. Would a different Impact wrench work better?
I had thought of picking up a HF EarthQuake - seems to get decent reviews. I also tried it on an old Speedaire compressor with a larger tank - still no go. Is it the compressors? Or the Wrench?
Thanks for any advice.
Sureshot
Bridge Creek, OK
The gun. You need a "twin Hammer" gun. It will have way more power. I use a CH (Cambel/Hausfield) for removal but a single hammer cheapy for instal. The CH has held up for many years of regular use without breaking the bank. It is a PL2502. I just googled PL2502 and it looks to still be in production.
SteveU
Cheapest way to find out is to get some HVLP fittings & put them on your line & on your gun, if it won't take them off then it is the gun. The increased airflow (not pressure) makes a big difference in how well any air tool works. If after putting them on & it doesn't work just remove the one on the gun & put it on the new gun when you get it. With the HVLP fittings on a 1/2" Nitrocat we haven't found anything on cars or light trucks it wouldn't loosen or break off.
mattrogers
Portland, OR
Why not try cranking up the pressure to 120 psi for a moment to see if that makes a difference? I wouldn't leave it at 120 psi for ever, but it's a cheap test for "right now"
theoldwizard1
SE MI
Crank the regulator up to about 125 psi. Your impact should handle that. (If not it really is a piece of **** !)
90 psi is for tightening, and you ALWAYS need to double check with a torque wrench.
Sureshot
Bridge Creek, OK
I have never used a regulator or dryer on mine. Used to use impacts alot but less now. Occasional oil. Should rig up a dryer though.
L
lineman88
Massachusetts
When I cranked it up to 120psi no difference. Then, I switched to a 25' hose from a 50' hose and it worked - not great but it worked. I'll try picking up a HVLP connector and see how that goes. Probably a better impact wrench would help. Do better impact wrenches typically translate into more power or just better longevity?
Thanks for all the input.
