tool protection?
born lucky
I need to clean and prtect my tools. I noticed that the garage I am renting (house) has too much moisture and my tools are being to notice the weather! I have read on Corrosion X . Is this product worth the extra cost and with Corrosion X product is best?
Merkava_4
Clovis, CA.
I can't comment on the Corrosion X, but I clean rust off of tools with Maroon ScotchBrite; it's a fiber pad designed just for metal; not to be confused it with the Green ScotchBrite pads you clean your dishes with. After that, soak'em down with WD-40. :thumbup:
Charles (in GA)
50 mi south of Atlanta
eschoendorff
I use corrosionx and it works well for me. My garage gets REAL moisture laden at this time of the year and the only things taht I have noticed a problem with are two impact sockets - a Craftsman and a Snap On. I wipe all my tools down with CorrosionX, but I think I may have missed those two sockets... they are sporting some surface rust.
I like CorrosionX... I use it almost exclusively now where I would have ordinarily used WD 40. For penetrating oil, I still like PB Blaster though.
www.corrosionx.com
jay50
Read the title of this..."Tool Protection"....
LOL, need to watch where you put your "tool" and determine level of protection...LOL
Charles (in GA)
If you want a good protector, AMSOIL MP (Metal Protector) in a aerosol can is very good. it dries to a waxy film, so you would not want to coat stuff you handle and use with it, but protecting something in storage, or something like the column of a drill press, it works real well. I've got a number of things that are beginning to show some signs of rust, need to get busy and start protecting them myself.
Charles
eschoendorff
Okay... I gotcha.
unsung
Illinois
Is there any type of moisture absorber that can be put in the boxes? Sometimes when you buy some things they are packed with desiccants, is there anything similar that would work?
lucasd2002
ATL-ish
Charles
I just ordered some of that last week. Good to know someone has had good luck with it. I ordered one can of the regular and one can of the HD version so I could try them out.
kythri
Lebanon, OR
Check out gun stores for some larger packages of the dessicants, and check Google, you can buy 5-gallon buckets of the stuff...
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Either the dessicant packs or they make a paper that is impregnated with something that will keep moisture from ruining the tols. We have it in all our gage block boxes at work. I'll try to get the name off of it.
Treeman
Anyone try this product:
http://www.bull-frog.com/products/
This product claims to emit some kind of chemical molecules that attach and/or protect your stuff from corrosion.
Seems like there are too many openings in a tool cabinet for dessicants to be effective, unless you had a large amount in there.
kythri
Lebanon, OR
That's a lotta revolver for a front pocket.... do you wear clown pants or something?
I can't speak for Jay, but I'm 6'9", so I've got a lotta pocket for it...
Even then, that's still a little baby Smith - a 686 in .357 with a 4" bbl. It's tiny! :bounce:
nissan_crawler
Wichita, KS
I know Rolls Royce jet engines come with about 20 5lb dessicant bags in the shipping container. They work great to throw under the bottom drawers of the box, not that it helps you much...:lol_hitti
M3Pilot
Eastern NC
I'm under the impression that cheap kitty litter works well as a dessicant. Also if you store your tools in a reasonably airtight place,a block of camphor in the toolbox will help prevent rust. I would think that if the tools are stored in a reasonably airtight place a golden rod,such as used in gunsafes,should help.
Jbullfrog
Avoca, Iowa
Ask your pharmacist... My sister gives my quart bottles of silica packets that they have pulled out of their bulk pill bottles at the pharmacy. I have them in my tap and die sets, impact socket trays, puller sets, and in my truck toolboxes. They seem to help, but I still wipe my tools down with an oily rag.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Aren't the tool warranted from rust anyways?
Do they even sell camphor blocks anymore or was it taken off of the market? We Toolmakers ussed to use it all the time, and in a pinch would clear your sinuses. LOL!!
