I am getting ready to build a garage with floating slab with stem walls and have a question about the stem walls.The stem walls will be about a foot above the slab.Should I block out for the overhead doors and let the slab sit ON top of a stem wall at the garage door opening or should I leave the stem wall and footing out of the areas where the overhead doors will be? Cost difference is not an issue just seems as though it would not be needed and would allow the entire slab to be independent of the stem walls. Also would make the pour much easier to leave them out as I could back the truck inside the foundation forms to make the pour
case464 is online now Report Post Edit/Delete Message
