How do I clean this carbide burr?
FastKat
I have a carbide cutting burr that I need to clean. I was using it to cut a metal edge under a car and I ran the burr over an area that had heavy undercoating. The undercoating clogged up the burr. The burr now has "rubber" melted into the flutes. The rubber is mixed with tiny steel splinters/shavings. I tried using an awl to clean it but I don't think I will be able to get all of the rubber out.
It's a 1/8" shaft with a 1/4" head. I attached a picture. Any suggestions on how to get this nice and clean again?
F
FastKat
So a wire wheel won't dull the edges? I mean, I know it's used to cut steel but still...
G1GRANDEUR
What I meant was just get hot enough to scrap it off with wire brush or small wire wheel. Not heat it up glow red.
Olafur
Iceland
Sometimes when burrs fill up like that; using wd-40 on it (or whatever rust-oil is close by) helps keep it clean - and really speeds up the work process. IIRC this works for aluminum grinding.
So you could try wd40 and just grind some soft metal. Should clean the gunk off pretty quick.
usdemt
South Dakota
When used some roll on bed liner they said to use Xylol (available by the paint thinner) to clean up the mess. Worth a try, and keep it around to take of adhesive residue, it works wonders for that.
otis66
I would use a pick to scrap the large stuff out. I would then soak in thinner or use brake clean with a nylon brush. A hand cleaning brush works nice.
brucer
propane torch will work...
the burrr is solid carbide, it wont hurt to warm it up with a propane torch..
carbide doesnt have temper..
propane torch and wipe the bed liner off with a rag..
browntown
Salem, OR
I might try using it on a piece of wood. I've done that with gummed up drill bits before.
Also, when it comes to solvents, my standby is the heavy duty stuff in the corner of the garage:
qBO5qs1lVrJqorgcGJpU2aifY5iNcSh-NnVqO4hk700YZQJfNCu22uVj88fZYw_yfywfKTHVEpgM8q1AsmzrZMKuWedanoSBIWlVseJtEKFayJ7lC0FBdPbVf_A7z6NigDYoIEhKJWzy5wn2LN-4lIL8q3CHxlOHMVFy-Gf7XqrcHYJcsq_KZWVlNk6Cbw
rlitman
Long Island
Exactly! You won't mess up the temper with a torch. Just keep the heat to no more than a very dull red. Any hotter, and you risk damaging the braze between the carbide burr and the steel shank.
I've got a number of carbide burrs that came with explicit instructions to do just that when they get clogged with sawdust too.
crankshaftdan II
Milwaukee, burbs.
Left to right:
File Card-used to clean junk out of file tangs
Regular wire brush-more H.D.
Tampico-stiff gentle bristiles for final dirt removal
Soak in cleaner-like previously mentioned-brake clean-solvent etc. and clean away!:thumbup:
