Metal projects
jomobco
Denver, CO
It depends how much I need. I like places out here in Denver like DenCol for bulk. I'll hit up Murdochs when I've got something small for angle iron, etc.
motify
Steel warehouse 35 miles away. They have everything I need. They cut long stock in half and load it on my pickup. I pay them and head for home.
csargents1546
Westminster CO
Use to get my small steel pieces from a surplus yard Denver called K and K surplus. Awesome place. Had alot of misc items. Never knew what you would find there. Most home improvement stores do stock a little steel. Pricey compared to a steel supply house.
38Chevy454
Cincinnati, OH
When you go to the steel supply place, if you need or can use shorter lengths; ask if they have a scrap barrel or area that you can look for small cutoff pieces to buy. You will still have to pay, but you can sometimes get a better deal since they are selling what otherwise would be just scrap for them. Problem is you never know what might be there. I have had some luck getting pieces this way. Otherwise just buy what you need. Std lengths are 20 ft, so bring a trailer. Some places will cut to 10 ft for free, others will charge, so bring a sawzall if you only need a few pieces and cut them yourself to save cutting charge if it is too much.
mmb617
PA
I have a steel supply house in town if I need quantities but the pieces are all 20 ft long and there is a minimum amount you have to buy, usually around 200 lineal ft.
For smaller projects I used to buy at Lowes but the prices are way high. I've since found a place called Surplus City just outside of town that has a good selection of smaller pieces of angle, bar, flat and sheet steel with prices much less than the box stores.
bhalv
Boise Idaho
local steel supply yard and usually from their drop piles, the stuff that gets cut off ad left from other orders, usually at 50-60% of retail
nichboy
Oklahoma
I just bought 10 sticks of 1" tubing yesterday. what is that black coating they apply to the metal (i assume its to prevent rust) that stuff gets everywhere, what should i use to remove it? Thanks
bobadame
Dawn dishwashing detergent, hot water and Scotchbrite works pretty good.
stokessd
Grantham NH
I use metal supermarkets, they aren't the cheapest, but they are super friendly and accommodating (in my area at least). And they can cut to surprisingly tight tolerances. I used to leave like 1/4" on my cut lengths to clean up on the mill, but after a few experiences with their cutting, I have shrunk that up to 1/32" or so.
I now stock very little at home (mostly jsut scraps from previous projects), and let them be my warehouse.
http://www.metalsupermarkets.com/msc-storefinder.aspx?map=US
Sheldon
Kirkvkid
Syracuse, NY
Depends what I am doing. If I was going to build a trailer then yes to all of the above. But for random projects around the shop I usually use metal bed frame rails. My buddy and I used to grab them whenever we saw them at the curb. Just look around on trash day and grab them. It's getting harder now that scrap is so high, so we hit up a few garage sales or estate auctions. 12 foot worth of angle iron that has paint on it isnt bad for $5, plus you might get a headboard for the burn pile as well.
I know it's kinda cheap, but again this isn't for some high dollar product I am selling to make a living from. I just ocassionaly need some metal.
JoeMama
I also recomend K and K if you are in the Denver area. Also Alreco is a great place to find Alum stuff.
csp
Franktown, CO
x2^^ C&M Iron Works is another good supplier that has salvage you can go through like K&K does.
Is he talking about mill scale? I don't know what is black and can be washed off.
I assumed he was talking about mill scale also. No combo of Dawn and a scotch brite is going to remove mill scale effectively.
I'm guessing he's talking about the oil that is left on some tubing.
If so, I use Acetone, Mineral Spirits, to clean before welding or painting.
crewchief888
NW indiana
most of what i use is scrap.
bedframes,
i get some steel from work, always small quantities, to fab brackets and "one off" mounts.
big box stores if i need something quick.
couple of local steel supply houses.
i can usually get what i need from the "drop off" pile.
:beer:
Stephenw
Utah
Tubing, square or round, does not usually have mill scale. Mill scale is found on hot rolled angle iron, bar stock, and plate. The black oily coating is actually lubrication used in the forming process. I bring gloves with me to the steel supplier. When I get the steel home, I wipe it down with rags soaked with wax and grease remover (from the autobody supplier).
ert01
I always buy from the scrap yards around here. They have new stock that I can buy in 10' lengths for cheap, or salvage metal/cut offs I can buy by the pound.
I needed some 5"x5"x0.25" square tube for a project. The metal supermarket wanted nearly $150 for 4 ft of it. Found some scrap in the yard and bought 8 ft for $25 instead. I always goto the scrap yard first now.
