GoBlue
Im speaking of the newest version of this gun. I cant find a grease fitting anywhere! Is this like a Snap on where it has a continuous oil bath or what?
My HF EQ 3/8 ratchet has one, little round dimple with a ball bearing looking seal.
I wondered the same thing because in the instruction manual it mentions putting grease in it.
Just thinking logically, if they wanted you to grease it there would be a fitting on there like the last one. It's a solid impact, you can tell that put a lot of effort into designing (ie copying) it. I personally don't take it apart to grease it, just use air tool oil.
Why do you need grease? just put some oil in everyday and your fine.
This isn't completely sound logic, for reasons mentioned above. Plus, oiling it will not do anything for the hammer mechanism which is a sealed compartment. It is identical to suggesting transmission fluid does not require changing as long as the engine has oil in it. (as noted, many transmissions are not easily lubed these days, but they all still require it)
I tore my old earthquake down after a while. The grease had hardened and separated. Seems that the lighter oily liquid parts seeped past the seals, leaving a dry crust inside.
For the record...
I pulled my gun apart 10 min. ago (slow at work)and it definitely requires grease. My gun was pretty much void of any grease what so ever! I cleaned out what little was present and re greased it with a quality high temp grease. I wish they put a damn fitting on this thing...this is going to be a pain in the **** over time.
That's good to know. What sort of grease is the best for this situation? Also, generally when I take something apart and try and put it back together it runs worse. So I might skip it. Haha.
I just got one of those guns. Sounds like I need to take it apart. I haven't even used it yet.
that is why it will blow up when the warranty expires ..china dolls
He also bought this gun less than 2 months ago. AND like I mentioned before. HF is a history of inconsistent lubing, which means your new impact may or may not have enough lube out of the box, even then it may be of questionable quality.GoBlue uses his pretty much every day in a shop environment. I'd guess that unless you do as well you'll not need to disassemble and grease before you use it.
I would hesitate to install a fitting. You don't really want to pack grease in there, just give the hammers a nice coat and call it good. I wouldn't think you'd have to do it more than once every few years.
Cleaning, Maintenance, and Lubrication
Note: These procedures are in addition to the regular checks and maintenance explained as part of the regular operation of the air-operated tool.
1. Daily - Air Supply Maintenance:
Every day, perform maintenance on the air supply according to the component manufacturers’ instructions. The lubricator’s oil level needs to be maintained and the moisture filter must be regularly drained. Performing routine maintenance on the air supply will allow the tool to operate more safely and will also reduce wear on the tool.
2. Weekly - Grease Lubrication:
Lubricate the internal mechanism of the tool, using white lithium grease through the grease fittings.
Poster above mentioned "white grease" this is usually lithium grease, don't use this as it causes the seals to fail. I've had this happen to transmission seals that had white grease used as lubricant. I found out at a tech seminar that this was the cause of the problems I was experiencing. A tech guy from Moen also told me they had trouble with orings in their faucets due to use of lithium grease.
Stick with wheel bearing grease and be sure no water can get into the bearings.
So, any guesses as to what sort of grease/lube to put in there? What is this high temp grease that GoBlue speaks of? Only lube I have ever bought so far was wheel bearing grease but that looks way too thick for this application.
Edit, found this:
http://www.amazon.com/dp/B000BHKTBW/?tag=atomicindus08-20
IR 105 Grease for metal impacts...seems perfect for this Earthquake...thoughts yes/no? The last Earthquake was certainly based off the IR 232, not quite sure on the new one. But it's a metal housed impact not titanium for sure.
