Attic ladder for 12' ceiling??
soapii
SE Michigan
Anyone have any suggestions for an attic ladder for 12' ceilings? I see Werner and Louisville both make a aluminum fold up style for max 12' ceiling. I have 24" OC truss spacing and the trusses run the way I want the ladder to pull down so it should be a simple plug and play install. Just trying to get some feedback from people who have already installed one.
Thanks in advance.
--Joe
akdiesel
Wasilla, AK
Is this a shop or house?
I do not have attic stairs in my shop but I used to have attic stairs in a house that had 8' ceilings. I feel the 12' would be difficult to travel in that length with items since most of those ladders are steep and narrow and no handrail.
gatchel
West of King of Prussia, PA
Most 12 foot pull down ladders I have researched required 25.5" rough opening size side to side. You 24" OC truss spacing might not work. Double check the specs on the ladders you are interested in.
This is the one I used:
http://louisvilleladder.us.com/products/attic-ladder/aluminum-en-2-3/everest-series.html
It works...It's not the best build quality but I haven't had any issues with it. I guess it's what you get for being made in Mexico...
Edit:
Here is the werner 12' ladder specs:
http://us.wernerco.com/view/Products/Climbing-Equipment/Attic-Ladders/A/A2512
Brad1234
I did what i though was the perfect solution. I bought a 10' fiberglass ladder instead. I can use it to get into the attic & anywhere else that I need it.
lzicc
Pittsburgh, PA
I'm in the same boat. I saw the one with the 25" RO, but I would have to cut a truss for it to fit and I don't want to do that. I did find one with a 22.5" RO, but the it is priced at about $450. :shocking:
Thanks in advance.
--Joe
Gregory M
shelley, idaho
check my post here at G.J. i have a Louisville Ladder that i got from home depot
her is the model number and price. mine works great you have to modify the pull down bar to get the ladder all the way down from the hinged up position for storage other wise it will beat the hell out of you as you straighten it out. but i like it and its out of the way.
Louisville Ldadder Everest 12 ft. x 63 in. x 24-1/2 in.
Aluminum Attic Ladder 350 Lb. Load Capacity
(Type IA Duty Rating)
Model AL258P
$239.00
Internet Special
$239.00
gatchel
bill9860
Northern VA
My ceiling is 12.5" used a pull down but the longest they make is for a 12' ceiling. So I built a "step" and the ladder feet rest on that when I need to pull it down. Works great.
easyrider13
Sarasota, FL
I have the same issue. 12' ceiling.
My contractor left me with a rough opening of 22-1/2" x 66-1/2".
It looks like my closest practical fit will be Louisville Everest AL228P which is 22-1/2" x 63" for $278 at Home Depot.
I see an American Stairways Husky 1200 (22-1/2" x 66") on the internet, but I can't find anywhere to buy it at an affordable price.
