98TJ
http://www.northerntool.com/shop/to...rage + Organizers>Tool Boxes + Chests-_-23630
55 3/4in.W x 21 3/4in.D x 20 3/4in.H
Saw a few in person. 36". 41", 56".
That's why I am baffled when people make claims you can't add-on with the 56". It is a VERY common size.
If I remember correctly, the 72" HF roll cab (no longer sold there) was the same as the Torin 72". So perhaps the 56" is the same as well. If that is the case, the top cab will be fine considering Torin offers the top cab add-on posted above.
I'm going to stop by Northern Tool this week and check out that they have.
I'm out of town but to the best of my memory the top surface of the HF 56" is 56" x 22 1/2".
Do they even match? Looks like the HF is gloss and the Homak is what the old HF boxes use to be.
Could be the pictures though!
"Can Not" and "Should Not" are two different cases. The manufacturer of the US General 56" says that you should not put a top, nor side box on that model. It's rated load capacity would be exceeded.
Adding the HOMAK pictured at the start of this thread - could add as much as 1000 lbs to the top of the US General 56" roll cabinet. That's 1000 lbs more than it is designed / spec.'d to carry by the manufacturer. That is the reason US General offers no top nor side boxes for the 56" frame.
HOMAK 23630
Weight Capacity is 800 lbs
Top Box Weight apx 200 lbs {244 lbs shipping weight}
If one is going to buy the HOMAK top chest - then they should put it on the rool cabinet that is designed to carry that weight. ie the HOMAK 56" bottom roll cabinet.
FWIW,
Carl B.
Looks like everyone missed this post.
Good info though. Thanks man.
I doubt anyone missed it, it is just one particular poster who has brought this up several times to encourage others to consider the 40" HF box.
Even after it was explained that the 56" has more reinforcements, some got caught up on under/over rated "specs", which btw exceed the casters before the box.
Can't get too hung up on HF literature, because it's widely known to have a LOT of errors in it.
It is then assumed that everyone's intention is to max load every drawer including the additional ones they gain from a top, when in fact they may very well be using it just to "spread out" their tools and make them easier to find.
Eh, I'm sure most just refuse to believe it.
I'd love to see the documented "more reinforcements" than the other HF boxes. Where are the reinforcements? The drawers? The frame? The top panel?
Check out that Snap on vid I posted in the 56" review thread. Very enlightening, albeit biased view on toolboxes and building to support weight.
So many here just say "Hey, look, it's shiny and similar in looks/cosmetics to a Snap on box, must be exactly the same for 1/8th the price." It's amazing that these are typically the same people that bash Snap on owners for buying Snap on just for the look/prestige.
These things are built fine if you plan on putting fluff tools in it, or poorly maximizing the space in the box. If you plan on loading the drawers with sockets/ratchets/airguns/wrenchs/ and other heavy tools. You may want to consider how well they do truly weighted down.
I too would love to believe these are the exact same thing as a Snap on, and just don't have the name on them, but it's simply not true.
Now, if you're buying it with the expectations that you may be getting a box that's half or 1/4 as good for 1/8th of the price, you just might be right.![]()
No Menards doesn't carry them, but I believe Runnings Farm and Fleet does.The Homak name seems famalier, does Menards carry it( I use to work there along time ago). Maybe its the local Farm and Fleet that has them
Why is there all this talk of snap on? No where did I state it was snap on or comparable or anything else of the sort.
I am only pointing out a few things. The manual first off, does not claim "do not use side cabinets or top chests"
That is a twisted (intentionally?) misrepresentation of the warning not to exceed maximum load capacity, injected with an assumption that all drawers would be loaded to max capacity and overload the stack.
Anyone here on GJ have first-hand experience with the Homak units? I know they're Chinese units, but if they're comparable to the HF 56in roller in quality I'm sure several folks here would be happy to put the combo together.
Nobody said you did. I brought it up, not you. It was an observation i'm making. Please don't take me quoting you as an indication that i'm only going to address points you've made.
The manual may not claim that, but i'd say if it's got load ratings that can be reached by simply loading the drawers on the cab itself, that typically means that you shouldn't put another cab on top of it and load those as well.
Kind of like if your GVWR on your truck is 4800lbs, and the truck weighs 4,000lbs, and you currently have (4) 200lb adults in it, you probably shouldn't try to tow a trailer as well.
I didn't know they abandoned that product. I thought it had been a popular item?
Not a good example in the real world. While I am very safety conscious and don't believe in overloading if possible, many motorhomes come from the factory WAY over the GVWR.
That's before you climb in, add your stuff, put in water, gas, etc.
I've seen new motorhomes that were 10% past maximum, on the showroom floor. People then buy them and drive them fully loaded, or would you say, overloaded, for years.
GVWR is much like the 'recommended' maximum weights' in that it is not issued by builders, issued by liability lawyers.
A 'half ton' pickup often carries a ton of cargo. A '3/4' ton pickup often carries two tons of cargo.
Most people tow way beyond what the lawyers recommend.
Tool boxes are the same, or even more so.
Look at ladders. Follow the recommendations and you won't actually climb one of the dang things.
