IDidntDoIt
- Joined
- Jan 5, 2012
- Messages
- 54
Did an outer tie rod end yesterday. Whoever did it last must've put the nut on at over 100ft lbs. Laying under the car jacked up, barely any room, and I couldn't back it off at all. I even tried using a pipe extension on my crescent wrench and it wouldn't budge. PB blaster and still no go. Should've only been on at about 42 ft lbs, easy removal. Typical.
I ended up buying two 10'' locking pliers and undoing the tie rod end first. Then I clamped down on the tie rod shaft and backed off the nut, had to push on the pipe with my whole body.
Just wondering if there's any tools or techniques that could've made this easier.
