what do you use for grinding welds ?
donnie m
wisconsin
:confused::confused::confused::confused::confused::confused::confused:
i searched the threads so i don't post a topic already covered but I could'nt find anything....( i'm sure it's here but i can't find it) what do you guys use to grind down welds.....i've always used a simple grinder with a stone wheel but i'm sure there is an easier / better way. thanks in advance:thumbup:
Jeeprz!
I was under the impression that flap disc's were for grinding welds, I guess I was wrong on that assumption.
tyndall
Nope. I use flap discs. Unless I really bork something up, then I use a grinding disc.
mattrogers
Portland, OR
I'm particularly fond of the Camel Grinding Wheels' Zirconia flap discs on my 4 1/2" angle grinder. The one I've been using has lasted me for about a year now (I'm not doing production work, but still, it's a long time).
Monte
Germany
carbide burrs with a die grinder or flap wheel/grinding disc with a angle grinder for fast removal and flap wheels/fibre discs to smoothen the welds.
carbide burr:
to smoothen the welds after using the carbide burr you can use mounted points or the tool pictured below which leaves a really smooth finish:
for fast removal with a angle grinder:
different fibre discs (2", 3", 4.5") for a smoother finish and to level the welds, grinding wheels take off to much material, flap wheels with a finer grit would be an option too
these (on top) are great for **** welds:
these too: (and for concave + convex surfaces)
and these if you want to see what you are doing... :)
D
donnie m
wisconsin
thanks so much for going out to the shop and taking pics....i'm sure this will help alot of us out.:beer::beer::beer::beer::beer::beer::beer::beer::beer:
e-tek
Saskatoon, SK
I've been grinding welds for more than 30 years and I can't imagine a carbide burr does much - or very fast.... does it? I was actually just using a burr in the shop today and it barely cleaned rust off.I aslo have very little luck with flap discs. They get used up way too fast. I rely on stone grinding wheels, then 40 and 80 discs.
I do like them see-through discs though!
Monte
Germany
sometimes only a burr fits, in a corner for example, and at least the ones i use remove material faster than any mounted point, if not maybe the teeth are not sharp anymore ? Or its clogged ? Or the teeth are too fine ?
these flap discs are pretty good: They have a thick layer of abrasives and last quite a while
<iframe width="560" height="315" src="http://www.youtube.com/embed/IxyTtgz1hGM" frameborder="0" allowfullscreen></iframe>
Drisco Z71
NE
Maybe if you guys had prettier welds you wouldn't need to grind them down?
Just joking guys, don't hate me.
I bought about 20 flap discs from these guys and I'm impressed because I'm still working on the first one, for the price I don't think they can be beat.
http://www.heleta.com/
e-tek
Saskatoon, SK
Maybe you're right - I used a couple I bought at Princess Auto (our HF), so they where not exactly quality....and decided they didn't last long. I'll have to retry with a better brand such as the one you're using - thanks.
Jack Olsen
Los Angeles
There's a whole spectrum from mega to mild -- depending on if you weld like me or like our own ZTFab. He probably reaches for a rag dipped in some solvent while I'm reaching for a 9" grinder with a grinding wheel on it. :)
Most of the time, I'll use a 4-1/2" grinder with a grinding wheel, followed up with a flap disc.
crewchief888
NW indiana
4 1/2" grinder with a grinding wheel,
followed by various grits of disks, or a flap wheel
all depends on what i have on hand at the time.
:beer:
gmwelder86
Oakdale , ca
depends on the task, am I ginding down a weld to put another pass over it? Or am I trying to make it flush with the base metal? Most of the time is starts with a 4.5 grinder with a 1/5 grinding wheel, after time you get good enough to control how much material you remove and to control the grinder. After that it may be a flap disk or wire wheel depeding on the occasion. I have a 9inch grinder but that only gets used to bevel material for the most part.
quattrojon
England
My brother is a fabricator/racecar builder, and he uses carbide burrs for dressing welds.
He has found that the best carbide burrs are made by Alpen.
Monte
Germany
oooops ....there is the problem.... The abrasive material used for cheap discs is inferior to name brand OSA certified manufacturers of abrasives. Please look here for a list of manufacturers of quality + safe abrasives:
http://www.osa-abrasives.org/englisch/seiten/2mitgliederverzeichnis.html
e-tek
Saskatoon, SK
WHT
Old school here (structural welding certification training might be more lax now).
Unless the weld is only for decoration, you shouldn't grind a weld except for grinding and feathering your restarts.
Andy Griffith
Western WA
Regular coarse grinding disc on large grinder for really cutting down a medium/large sized weld. 7" and 9" are the sizes I have if I recall.
Followed by a flap-disc 4.5". I find the larger sized flap discs on the big grinders working on largish welds just don't last that long. But the flap disc in a 4 or 4.5 size works well after the weld is cut down a bit or on a smallish weld.
For finish grinding or grinding down a small weld I absolutely love the red roloc discs on a 90 degree die grinder.
For really tight areas I have used the burr on a straight or 90 die grinder at times.
And if it needs to look really pretty for some reason I like a small knotted wire wheel in the die grinder.
Monte
Germany
That's a VERY German list!! But thanks, I'll definitely try something different over time. I'm surprised Quatrojohn's brother also uses burrs....
You can also try something american like Norton, should work too :)
SWells
Alberta, Canada
I use a grinding stone on my 5" angle grinder, start with that and move up to a flap disc if you want it purdy. The flap disks are great but I find they burn up a lot quicker than stone (and are 2X the $$ too).
greasemonkey44
memphis
i usually use a stone; its cheap and ready to roll
i have also used a flap wheel and roloc before
honestly though unless you are doing body work you shouldnt grind a weld
Monte
Germany
These look good with built in thread and plastic backing pad for easy trimming:
gmwelder86
Oakdale , ca
What ever you buy I would stay away from the new diablo stuff they are carrying at HD their are garbage, dont last long as all. Nortons are my perfered brand and are avaliable most places
