It seems like there are 2 rear caliper piston tools are available...
tanda4
IL
1. Lisle
2. Astro/OTC/Harbor Freight/KD Tools, etc.
Is there anything else? Even the Blue Point kit looks like Lisle. I already ordered the Lisle kit, but was wondering if anything else is available.
eschoendorff
If you already ordered the Lisle, what difference does it make? It will do the job and finding anything else is probably going to be more trouble than it's worth.
BTW... we already went through this with a certain Blue Point purchase....
krusty the clown
Member Emeritus
niangua, mo
i think he's talking about the tool that screws the piston back in for the park brake........if so then the lisle is the one you want.
ImportTuner
I have the KD, the one made by OTC, and a real nice one made by Facom ..
billymade
New Mexico
Harbour Freight makes a really good one for $29.99! LOL! :lol_hitti
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40732
PoorOwner
CA
I just have a little cube with different faces to handle most cars?? cost $10 from Kragens.
gotmud13613
Upstate, NY (Brasher Falls)
I have that one... but never used it yet. Is it really crappy, or is it actually decent?
I'll admit I got it, but it was on sale for $14.99. I have only used it once so far but it seems like it is good enough to get the job done, I am not sure if it'll hold up to everydayday abuse but for the average weekend wrencher it should be fine. I don't do alot of brake work usually my own or family & friends. For the price who can complain ?
eschoendorff
That was my rationale. I would use it once in a blue moon too...
Just haven't needed to yet.
krusty the clown
Member Emeritus
niangua, mo
i thought the same thing about the hf set. i bought it and used it twice.......it *****! that was the last hf purchase i made. if i did brakes more often i'd buy the lisle set and bring the hf one home.
krusty the clown
Member Emeritus
niangua, mo
the screw threads are a different pitch than most calipers so it constantly comes loose in use (unlike the lisle) and the drive end is help on with a roll pin that constanlty falls out, so you spend as much time looking for it as you do working. and lastly the lisle pucks are held in place with a square drive and a ring similar to an impact wrench so it stays in place, the hf one drives with pins so when the tools becomes loose in use it will fall out of position. all minor problems for the cost difference for at home use but a real PITA for use in the shop!
krusty the clown
Member Emeritus
niangua, mo
one side ( i think it's the right IIRC) has left handed threads. fedwrench posted earlier in this thread that sunex has a new tool for the fusion, i havn't seen it yet but it's worth looking at.
Merkava_4
Clovis, CA.
When I did my rear discs I used the piston tool to back the piston out with the caliper off the car, but I still had to dial in the right clearance with nose pliers once the caliper was back on the car. I'm thinking if the piston wasn't stuck to begin with, I wouldn't have needed the piston tool. Incidentally, I borrowed an SO kit from my neighbor; when he got the kit back, it was very clean. ;)
Moose-LandTran
The Brink of Insanity (England)
go with a kit where there's a hex on the wind-back handle. the t-handle are only so useful.
i always used a 24mm wrench, and a 19mm socket on a long Snap-on 3/8" ratchet for wind-backs. easiest way to do them.
there are lots of sets to choose from over here in europe, as wind-backs are used on almost all late-model euro and japanese cars. go with the biggest set that have both left and right handed winders.
krusty the clown
Member Emeritus
niangua, mo
Are those rear brake piston tools/cubes any good for the late model Fords?
i have one and it will work. the biggest drawback is that it's akwards, by that i mean it almost takes three hands, one to hold the caliper one to keep the tool engaged to the piston and one to turn the ratchet. but for $10 bucks it's an option if you only work on your own car. it became my at home tool when i bought the hf set.
