help with bench grinder
cactiki
Ridgecrest, Ca
Help I'm a dufus! I can't tighten the nuts that hold the grinding wheel on the shaft.:headscrat When I turn the nut, how do I hold the shaft? I thought the nut on the other end would be opposite thread but it isn't......:confused: what am I missing?
e-tek
Saskatoon, SK
Hold the (opposite) side wheel when you tighten the bolt. As well, they are threaded so they tighten when spinning.
C
cactiki
Ridgecrest, Ca
Well I thought that too, but it is not so. Tightening on one end loosens the opposite end.... neither end has reverse threads
nehog
Jaffrey, NH
I put a box wrench on the one I want tightened, and give a a light tap with a hammer. The mass of the armature is enough to allow it to properly tighten but not over tighten. Sometimes I just grab the other wheel (if it is tight already) with my other hand and that works too...
Same trick can be used to loosen the nuts, a light tap is all it should take.
1grnlwn
Central Illinois
If it will not tighten make sure the new wheel is not too thin and that your washers (if any) are orientated properly.
betterbillt
I have a 6inch that I used a dremel and made a slot for a screw driver. The 10 inch cinncinatti is easy to hold the other wheel and turn.
Jack Olsen
Los Angeles
Remember that the more you over-tighten it when you put the wheel on, the more infuriating it's going to be when it's time to get the wheel off.
bad_idea
Pasquotank, NC
Similiar thing can be said about a 4 1/2" grinder. Hand tighten the wheel and you can get it back off by hand. I don't own the special wrench for the 4 1/2" grinder because I don't need it.
Hand tighten the nut and then grab the grinding wheel and twist it to snug the nut just a little tighter. As you use the grinder it should spin in the direction to further tighten the nut.
C
cactiki
Ridgecrest, Ca
Thanks for all the ideas.:thumbup: I will have to try some of these... I was using the wire wheel yesterday and heard a jingly sound, turns out the grinding wheel was just spinning loose. It could have flown off!
