Sounds too good to be true. $1000? If I had the A) space and B) need for it I'd be knocking on his door. I emailed him anyway to get more details-- no reply eight hours later.
How do you transport one of these, anyway? Moving truck with a lift gate?
http://sfbay.craigslist.org/eby/tls/2817147281.html
Pic
Extreme Tool Boxes 55" 11 Drawer Tool Cabinet Tool Box Black - $1010 (dublin / pleasanton / livermore)
Date: 2012-01-25, 6:15AM PST
Roller Cabinet
55" W x 30" D x 46 3/8" H
(4) 6" x 2" casters, two swivel with brakes and two rigid rated at 1250 lbs. each
High gloss powder coat finish
Drawers with roller bearing glides
250 lbs. to 500 lbs. rating per drawer
Theft proof lock system
Tool Chest
55" W x 30" D x 26 3/8" H
Standard Features Included
Exclusive Patented Features and Designs.
No spot welds on drawer fronts, hutch or side cabinet.
Drawer latch assembly has a self-adjusting spring lever action allowing the latch lever to go up into the lock bar for increased security and smoother drawer action.
Drawer lock bar assembly uses single cylinder lock design for quick access.
Double steel wall drawer front design gives greater strength to each drawer.
Modular drawer design allows drawer configuration to be rotated.
Double channel spot welded support brackets on bottom underside of each drawer reinforces and prevents sagging.
Drawer back panel designed for rigidity to hold more weight without sagging or flexing.
Top Sub Weldment keeps the top of the box rigid and stable.
Side cabinet support bracket mounts under toolbox to give added support to side cabinet.
Tool Box frame design uses 11 gauge steel for stronger chassis and supports the use of heavy duty casters.
All drawers extend fully.
5 Year Warranty
Pic
Roller Cabinet
Tool Chest
5 Year Warranty
