machineing tool
larry_g
oregon
Valve seat grinding tools?
I would say more of a cutter than a grinder. Agree that they are for cutting a tapered seat concentric to a bore. Could be a plumbing or steam valve. Can you show one assembled? Does the cutter face away from the stem or toward it or can it be used both ways?
lg
no neat sig line
ptschram
Churubusco, IN
lg
no neat sig line
Good point, cutter, not grinder.
littletoes
NE Washington
Uh....why would you buy something that was "use-less" to you, at a flea market????? More money than sense???
And Yes, I have used some similar tools for grinding the seats on older control valves on steam and hydronic heating systems.
DandDMachine
Bloomington, MN
I believe those are old valve seat cutting tools. They would typically have a few different angles like A 30, 45 and 60 degree angles. The pilots are the part that would go down into the valve guides to center the cutting bits. Normally they would come with a few different sizes like 3/8" and 11/32" and each size might have a range of sizes to compensate for worn, or different sized guides. They did a decent job in the hands of a skilled operator. Not anything like you would get from stone grinding setup or todays high precision seat cutting machines that weigh in at a few thousand pounds. I have seen them go for decent money on ebay. Is there any brand name on them? Sioux is a pretty common manufacturer of those but there were a bunch back in the day.
