Barn/Garage using Socket Systems
BigAlVol27
I'm looking for advice on building a barn/garage with Socket Systems. I see a few threads on here. The Socket Systems kit says to use 6x6 rough cut kiln dried timber, however, I've talked to one lumber distributer and a guy and 84 lumber and they are telling me that they can't get anything like that. Any thoughts/suggestions would be greatly appreciated. Thanks!
BigAlVol27
I'm in North Carolina. Since I'm not a lumber expert, would a saw mill have to cut down an 8x8 to meet my deminsioins? I need 5 5/8 x 5 1/2 according to Socket Systems.
Shocker
Olympia, WA
IH is right. I looked very hard at that system. You just use 2x6 + some plywood and make a sandwich. Easy as pie.
Top Hat
I'm considering this socket system only because I want a second story with the most usable space. I am staring to have some reservations - I can never get any one to answer the phone - just a recording. The cost of one set of metal connectors seem pretty expensive, the web site seems a bit fague ie what is the size of the lumber required - it seems to me if I can't get lumber from a local supply the cost is going to go a way up any suggestions on barn style building with a second usable second floor.
theoldwizard1
SE MI
A vaulted parallel chord truss gives you a lot of space.
Not as much storage as a gambrel roof.
Check locally for a truss company. The will can fix you up with gambrel trusses also. In most cases, trusses are not DIY. They have to be designed by a certified engineer. and built by a certified builder. In many cases they have to be installed by a crane.
theoldwizard1
SE MI
A saw mill would cut what ever you want out of a tree that is bigger than what you want. You give them the specs and they find the right size log and cut it.
The web site also says you can use LVL (laminated veneer lumber) or glulam. Both of these a "manufactured" wood beam, built to your specs.
A lot simpler than sandwiching 2x6's and plywood.
