Portable clamping work table
Tribalvision
Bensalem Pa
I am looking to pick up a clamping work table. I dont need a huge professional table. So what are the Part time woodworkers buying for a table? I'd try to build one, But I'd figure buying would be cheaper and have more options..
something like this?
Or should I spend a little more and get a quality table from Channelock,Rigid, Craftsman etc????
Get a Black and Decker WorkMate, Ive got 3 kicking around here. Two 200's and a 400. (Older Mod. No's. so new might be different).
They all have 3 work heights, well technically 4. folded flat you can use them at near ground level, about 6" or so. They have short extension legs that can swing out and provide maybe 6" of lift, and a wider stance.
Then you can extend them to the "normal" work height, and use them with or without the extendable legs. I use the different work heights all the time depending on what I'm doing.
The 200's have the basic sliding jaws, but the static jaw can be slotted in several positions for more capacity.
The 400 will do all the above, plus you can unlock the dynamic jaw and swing it up 90 degrees to a vertical position, and clamp downwards onto the static jaw. A handy feature I have used any number of times.
All come with the bench dogs, so you can lay a board on top and clamp it, or just use the jaws like a vise.
Once you have one, since they are VERY stable, you can mount up bench tools like grinders, arbor presses, even small to mid size machinist vises, onto a wood base and add a bar on the bottom to clamp onto and have whatever workstation you need and place it where ever you need it. I add a "safety plate" to the clamping bar (that bar has to be a little thicker that the WorkMate's jaws) so if it happens to vibrate loose it does not come out.
I don't think you could get away with that on the lighter "TV tray" designs.
Lastly, I rack a number of mounted tools into a 2 ft wide shelving unit that has adjustable shelf standards, and the mounting plate is cut to the correct width to allow it to become the shelf. this makes it so the clamp block on the bottom doesn't rock as it would if it were sitting on a shelf.
Here is a shot of a plate waiting for my next tool:
T
Tribalvision
Bensalem Pa
Thanks for the advice. After a bit of research it looks like the B&D Workhorse 425 will do what I need it to.
Thanks again
Steve
Andy Griffith
Western WA
The only thing that keeps me from using my old workmate is the stock height is absolutely killer on my old back. I should get it down out of the loft and see about making some sort of leg extensions or the like.
Larwyn
Texas
I know it is not a table by any stretch yet I all but retired my Black and Decker Workmates once I got my hands on a Triton Superjaws. I got this thing before Rockwell, Rigid and the others appeared on the market. Mine is an older model with absolutely no plastic parts. It also has the bracing at the bottom of the legs which they seem to have eliminated on the newer ones. I think mine was made in Australia while the newer ones likely are not.
The main advantage of the Superjaws and the ripoffs is that the vise is operated by your foot, leaving both hands free to position the workpiece. I'm not sure about the newer versions but on mine you release the vise by stepping on the stirrup and striking the lock with your knee, so you have both hands free to hold the workpiece as it is released. I have added two of the tool trays, one on either side. It's one of the handiest tools that I own.
Yep, that is more of a portable vise than a clamping work table.
That one in interesting as it is sort of an inverted version of the one Roy Underhill uses as a foot operated work piece clamp.
PCO6
Newmarket, Ontario
.. I all but retired my Black and Decker Workmates once I got my hands on a Triton Superjaws. I got this thing before Rockwell, Rigid and the others appeared on the market. ...triton_superjaws.jpg
Same here. I have a Rockwell Jaw Horse and it's great! Very strong and versatile. :thumbup:
Stuey
28m above sea level
Is the B+D Workmate really made in USA like this website claims ?
http://www.homedepot.ca/product/workmate-425-project-center/907322
My 3 earlier versions were; I've no reason to doubt the new ones aren't. The ones I've seen in stores haven't appeared to have had the build quality reduced.
Certainly there are a lot of cheap imported knock off's trying to capitalize on the basic design like the one in post 1. None of the imitators have impressed me at all. TV tray stability, and legs that I wouldn't trust with any kind of weight.
I've stood on mine any number of time and even clamped "walkways" between two of them. my old (heavy) 12" AMF DeWalt RA saw lived on top of my 400 with a 40X18 slab of oak step tread clamped by a 2x2 screwed to the bottom for about 5 years until I setup a better stand setup.
Monte
Germany
Just took a quick pic of my fathers one, i don´t know how old it is, but it looks like high quality (cast aluminium/steel construction). I dunno, but i think the new ones look flimsier (don´t know if they are...) The only other option would be Wolfcraft. But maybe i should look for a older version at the flea market ...?
machine_punk
Napa Valley, California
I definitely recommend you do NOT buy the HF VERSION of the work mate for cheap. I got mine for free, and it is 'just OK,' but I wouldn't spend money on another.
M_P
Monte, I've NEVER had occasion to gripe about the strength of any of my B&D workmates. And I can honestly say there have been times...
Whether your Dad's cast aluminum version is better I can't say. Cooler? Definitely. I've seen one or two at yard sales, but they wanted more than I was willing to give.
My only gripe about the workmates I have is I've broken the plastic catch that keeps the short legs folded up several times, and B&D still sells replacement catches (I just checked), and it is an easy fix. This is on the 200/400 (And I'd suppose the 300) series. Not sure what the new versions use, or if they redesigned.
