Howdy.
At work, we drill and punch a LOT of holes. I've organized the bits and taps in a way that I thought was more or less idiot proof, but we have some amazing idiots here. I set up a plastic parts box for SAE and one for Metric and even color coded and labeled them (sometimes even putting sample bolts in the compartments, too), but folks continually put the bits and taps back in the wrong sections, so we still have to double check them before use. Our present setup is below:
I've been discussing better ways with a coworker; we're thinking about a metal box, with actual holes drilled and tapped in each compartment or in the lid, so we can grab a bit and tap and check them right there might work, but we want it easy enough so that everyone uses it.
I was wondering what solutions or suggestions you guys have for sorting and storing bits and taps.
Thanks much.
Thanks much.
