bcradio
I'm looking for good quality hex bit sets (both SAE and metric) which have the 1/4" hex shank (ironic?) to fit in my multi-bit screwdrivers. Anyone know any good brands?
Apex? etc?
Thanks
Apex? etc?
Thanks
Wiha makes some really nice ones. I have a few of theirs, but only in metric. The rest of mine are mostly a mix of US and Taiwan Craftsman/etc.
Anybody know of any bad sets?
I've got the fairly expensive Wera bits with diamonds on the driving surface for grip, and I have three sets of Harbor Freight $8 100 bit security sets, magically they all seem to turn the same screws.
I think I've broken one from a Black & Decker set, and worn out a few phillips, but best one is going to depend on what your doing. Its real handy to have the HF 100 bit set since its got just about everything, and they are cheap so I use them when I have a painted over fastener and need to tap the bit in with a hammer.
vim has a nice set (they are the oem for snap on). They used to sell it on tooltopia.com. I was going to post it for you but they must have sold out.
Dewalt makes a killer set of impact ready bit set. They have several types of 1/4 hex drive available. I bought several sets off eBay saving over 100$. Home depot and lowes carry them and probably any hardware store that sells dewalt items has them. I have used other cheaper brands but the dewalt hold up best for me. I have the 59 pc and 29 pc sets along with several sizes of the ones I use most #2 phil bits.
I want some bits that are also able to be used in a drill or impact driver setting. That's where the HF ones have mainly fallen short for me.
How about some USA made goodness?
Metric:
Bondhus 11099
Bondhus 10899
Sae:
Bondhus 11036
Bondhus 10836
I am surprised see that; I bought several boxes of the CV tool steel from HF and they are going full guns for me![]()
I think using an impact driver on any bit that is not "impact" rated will certainly lead to a quick failure.
For daily hand use and drill/driver use, I;ve seen and use Wiha bits on a light to mediumd duty mfgr. floor tearing down and re-assembling 2 vehicle a day.
Never had a problem in half a decade with the Wiha bits. Flat, phillips and hex.
You want to use a std China made bit day in a day out on an impact? No way.
Buy impact bits, fork out the money and get the job done correctly. No shortcuts there sadly.
Got any recommendations for the good impact bits? I don't mind forking out the cash.
I don't, however, want the hex bits for an impact wrench, but rather an impact driver with a 1/4" shank. I also want to use these bits in my multi-bit hand screwdrivers when needed. Only ones of these I have seen that are for impacts are the dewalt bits which have been decent but not great.
Thanks
If you do not mind using torx head on hex. Milwaukee shockwave torx are very strong. I uses to used them till I moved to the wera impaktor
I was aware you are talking the 1/4" hex bits, and NOT the bits that are mounted to a socket, and I also understood that you meant impact driver with a battery and "drill type action", not the impact wrench type.
For PH2 impact bits, I use Milwaukee Shockwaves. But I;m not the person to give the best advise professionally for impact bit advise, as I seldom if ever use battery impact drivers for prototyping and custom work these days as it often does more damage than good. I use tools that are a bit more gentle in that area.
For std. bits tho., Wiha's are what I use and have sworn by for years. My toolbox is full of 'em.
wera impaktor? Tell me more
Are these rated for impact use? Granted 95% of the time I will use these with a hand driver, but occasionally they will see the gun
Just remember you will not find to many impact rated torx or hex sizes. Smaller hex size screws will not be able to take the punishment of the impact drive.
vim has a nice set (they are the oem for snap on)...
Are you sure that VIM is the OEM for Snap-on? Several posters here on GJ have indicated that Zephyr was the OEM for Snap-on bits. I have some SO bits that have the Zephyr marking on them. I also have some Brownells bits with the Zephyr marking and they appear the same as SO bits.
For a lot of applications bits are a wear item and need to be tossed as soon as they show any tendency to cam out. Thats why they sell PH2 by the 100.
Maybe look at some Apex bits from an industrial supplier?
Bondus on Amazon $17, for SAE & Metric, Made In USA
Another vote for Wiha. I use Wiha on electronics & since my RC days.
At work we use Wiha now too. We use #0 & #00 philips power bits at work daily. We've tried a few different manufacturers. Apex bits were too brittle, the tips often cracked under normal use. Haven't broke a Wiha yet.
I've heard lots of good things about Wera, never tried them though.
You mean the balldriver sets for $16.** each? Anyone used these?
http://www.amazon.com/dp/B000E7VG5M/?tag=atomicindus08-20
http://www.amazon.com/dp/B000E7XGUU/?tag=atomicindus08-20
I'm looking for a set of impact sockets for with 1/4 hex drive. Like this except high quality and proper latch features: http://www.amazon.com/dp/B000NPXHUM/?tag=atomicindus08-20
I have that set and they're not terrible for the price, but they don't latch in properly as they just have a straight 1/4 hex shank.
