I did not get to read each post as I am exhausted and going to bed, soon. So, sorry for any repeat info.
You said for occaisional use, but did not have a price range, at least I don't remember one. I bought the last one on Ebay-refurbished with a 5-year guarantee. I don't remember what I paid. A new one is just over $300 to $370.
Anyway, just throwing our three possiblilities.
1-
$99.00 and maybe use a 15% or 20% coupon?
High performance 15 amp motor
* Guide plate adjusts 45 degrees left and right
* Fully shielded bearings ensure smooth operation
* Spindle lock for quick wheel changes
* Quick release vise
* Easy access brushes
120 volt, 15 amp, 3500 RPM, 1'' arbor, Cutting capacities: 4'' round stock, 4-1/2'' square stock; Overall dimensions: 25-1/2'' L x 18-1/2'' W x 10-3/4'' H; Shipping weight: 36 lbs.
2- 14'' HEAVY DUTY CHOP SAW
* 3.2 HP, 15 amp, 120VAC, motor
* 3900 RPM maximum speed
* Heavy duty cast base
* One piece carrying handle
* All ball bearing construction
* 5'' pipe cutting capacity
* Angle cutting to 45°
* Five year manufacturer's limited warranty
Milwaukee# 6176-20
ITEM 39755-4VGA
$199.99
3-Milwaukee Dry Cut Chop Saw — 14 in., Model# 6190-20
72 and 90 tooth blades
The 6190-20 utilizes dry (a.k.a. cold) cut technology which will cut on average three times faster than an abrasive machine and costs 1-1/2 times less to operate. The saw produces little to no sparks when cutting and leaves a virtually burr-free finish. Cuts angle, unistrut, steel studs, channel, conduit, tubing and pipe. The base is a heavy-duty cast aluminum reinforced with a 1/4 in. steel plate. Tool-free 3/8in. vise and back fence. The horizontal D-handle provides optimum comfort whether the tool is on the ground or sitting on a bench.
Good luck on your search. I think you will be pleased with your new saw!
