What's on your walls? Neat storage ideas!
mdbeck1
Norman, OK
Build a "Playhouse" for the kids.
Note: if you don't have kids tell them you're getting ahead of the power curve for kids/grandkids...
bad_idea
Pasquotank, NC
playhouse? nah. dig an underground storage space in the backyard. put AstroTurf on the roof/ground so it looks like regular lawn from Google earth.
mdbeck1
Norman, OK
You could burrow down and make an underground complex. Lots of concrete and ramps for the cars. Hmmmm.... What to do with the dirt????
impala4speed
Youngstown, Ohio
[/QUOTE]
That really does look great. Wondering how thick is the plexiglass door?
Jack Olsen
Los Angeles
The top is 1/8" steel sheet. It's framed by 1/4" thick 2x2 angle stock. It's surprisingly sturdy. You can't burp the top at all.
And if I went much thicker with the top, I wouldn't be able to lift it.
bad_idea
Pasquotank, NC
Not really on the wall, but directly in front of it.
In scouring Craigslist I found an ad for 2 material carts for $75. I bought both of them for $50. Nice carts too. 26" wide x 6' long w/ removable side rails. They are made of 2x3x3/16" angle. Each cart weighs in around 75 lbs. I cut one of them down to 18" wide to fit in the nook beside the garage door in my smallish 14x20 attached garage. Then I welded tabs on the bottom of the cart to mount some drawer slides (scavenged from old office desks a couple years ago). Mounted these sheet metal drawers I pulled from a service truck at the local scrap yard to the slides (paid $2 a piece for them 5 years ago).
No more plywood falling on me while I try to get the sheet in the back. There is no more back of the wood pile! As an added bonus the drawers have slats in them perfect for separating my smaller scrap metal. I painted the whole thing blue with the same gallon of blue I painted the work bench and the vidmars.
nkachur
Manitoba Canada
That might not be mounted on your wall, but consider this idea stolen.
crewone
Indiana,Pa
Had a bunch of chain binders that needed a home
kyles974
Florida/Alabama
Sorry I don't have a pic for mine. (garage hasn't yet got finished)
But, I always hang my chains, bungee cords, straps, shotgun, etc., behind my garage door. I don't know why, but it's always worked for me.
I do think maybe because I don't use them much, and behind the door, they are out of the way.:thumbup:
oh, and I don't have as many as you do here!
crewone
Indiana,Pa
once my shop moves forward a few steps I need something like this too
It was real easy to make couple 2x4s and some angle iron plus two short
2x4s at the top to step it out
Yeah got a few dad got a bunch at an auction sale that he went to guess they was going cheap
crewone
Indiana,Pa
Car wheel cut in half with a shelve welded on it. Also notched to hang the torch head up when done so even if its hot I don't have to worry about it
thatcher
iv been looking for something like that to build for a while. the old popular mechanics tell you to use a half of a barrel. yours is better.
BlindViper
York, PA
I might use this idea but instead of the torches I am thinking angle grinders.
Zick
WI
So my floor started to get cluttered with bins, coolers, etc. You know all the stuff that doesn't get used very often.
Decided it needed to get up off the floor so I made this. Unistrut is awesome stuff to use and I found the metal decking at Menards which worked out perfectly imo. Still need to paint the bottom ledger board to blend in better.
twopints
Australia
I have more vertical space in my shop than horizontal space so I made this steel storage rack. I generally buy the steel in 20' lengths and cut it in two when I get it home. The rack can hold 10' lengths and clear most everything above. The shelves on the backside hold smaller pieces.
Because of limited space in the shop my general rule is to put everything on wheels/casters that can be done safely. Took a bit of experimenting to find the right angle that would hold the steel securely and not make the rack tip prone. As it turned out, when the rack is unloaded I am unable to tip it over even when hanging my big **** off the back, and of course when the rack is loaded it is even more stable. I put two pieces of chain on the back near the top with the idea that I could fasten them to the wall which may provide 'some' stability in the event of an earthquake.
Like the concept, what is the magic angle ? some dimentions would be grate
gahrajmahal
Cincinnati, Ohio
Who's got innovative ideas for regular stuff like yard tools - can't build a shed for that stuff so it has to share valuable space in our already crammed 2 car garage. I've already put shelves level with the garage door tracks to take advantage of that high space.
I have a pretty good way to store yard tools, shovels, rakes, brooms. The idea I stole from the Smith & Hawkins store we used to have here several years ago, before they sold out to Target. Their store was like catnip to gardeners. It had a raw concrete floor, the shelves and display tables were plywood with galvanized sheet tops. There were lots of great plants and flowers arranged nicely. On the corrugated metal covered walls were these black iron pipe racks that allowed them to hang multiple shovels, rakes and other heavy akward yard tools in a small amount of real estate. Here is my take on their idea.
I went to the big box store and purchased 12" black iron pipe threaded on both ends. There is one 4 hole flange and one cap per bracket. Each mount rack takes two of each. This is attached to the 1/2" plywood with 4, 1/4" carrage bolts installed with the nuts to the front.
Before you mount your brackets cut your plywood length to size and locate the wall studs you will be attaching to and mark this on your plywood. That way you won't inadverdantly put your pipe flange over the stud where you need to fasten the whole thing to the wall. I used 1/4" X 3" lag bolts to fasten the plywood to the wall. The sledge hammer, axe rack is 3/4" plywood for a little additonal strength.
Some of the Pairs are mounted close together and some are mounted a little farther apart. I just set the tools on the floor and stood the pipe flange racks up next to the head to find a good measurement between the tools.
Originally my plan was to have specific tools stacking on specific spots, but over the years the tools have changed, and my family doesn't always pay atttention where it came from so we just hang the stuff wherever it will fit. Occasionally a tool will fall off while you are removing one from behind, but you quickly learn to set the front tools down first before getting that back one out. We have had this up for about 15 years and it works great, keeping all the tools close to the door and has no strength problems or maintainance required. As you can see, you can also hang other stuff in between where the handles are.
Fifty Six MGA
Southern California
This is not technically my garage, it's in the shed, but it makes room in the garage:
The Bike Shed.
The Kayak shed - Gear is on a rolling rack so I can move it out of the way.
In the garage - I got all 4 metal cabinets off craigslist - $80 total. Tool boxes were off craigslist too, $120. Still needs organizing.
Long skinny stuff get's stored between the rafters:
Ladder storage:
I wanted to hang stuff on the walls, but it's concrete, and I didn't want to drill a zillion holes, so I built a frame.
Dan in Pasadena
Pasadena, CA
...I found the metal decking at Menards which worked out perfectly imo.
I've been looking for an idea like this. What is this "metal decking" originally intended to be used for?
There are no "Menards" in California that I know of, so I am wondering if Home Depot or Lowe's carries the same thing or something meant for a similar purpose?
Zick
WI
Here is the link for the decking.
http://www.menards.com/main/buildin...arage-racking-wire-shelf/p-1469454-c-9540.htm
I think it's used for some shelving units made by xtreme garage that Menards sells.
Jason Lister
Coarsegold, CA
Check Quantum Storage same high quality as Akron Mills at a lower price
I saw some of those containers on your site that looked like they had clear plastic covers. I did not see any information for the price of the clear covered containers though?
I really like those bins for organization, but they collect EVERYTHING in them. I would think the covers would be an awesome solution.
Alfster
I have been off work for a few weeks now recovering from a heart attack.
Needed a project so I have been reorganising and painting some of my old cabinets.
I have an old Hot Wheels stand that I picked up cheap when nobody else wanted it. I have cut the panels of it to make them into door liners and made some frames. These will be for a wall cabinet I am going to make to hold a bunch of magazines.
The 'door handles' are made from some old spanners I had lying around.
