I'm already over-budget on the garage, so I want safe power but it does not need to be Cadillac wire. Code is fine. If I want to redo later when funds replenish I have no problem digging the trench out again to add Conduit and other wire. I just want power without having to move the generator out there.
Sooooo..
Hey guys, Where do you find such wire? I don't need 500' of each. I need 90' of SER and 150' of mhf (or could I use URD?). Need 2-2-2-4 al, Where do I buy?
And to double check. 60 amp breaker inside house at main panel, ser inside (no conduit), transition to MHF in box outside (conduit to 24 deep) then 24 deep to garage direct burial (no conduit), conduit up and into back of Panel with 60 amp breaker? Wire size is 2-2-2-4 al the whole way, 210 feet. Additional 8' ground rods, 6' apart. Is that good? Thanks again all!!!
If you need details. Lighting- Eight 8 foot T8's , 12A 240 compressor , a little 240 welder , and some hand tool outlets. Maybe a lift later, much later. Just me working.
Sooooo..
