What do you use to clean your tools and boxes?
tlowery04
I know somebody on here I read used a wire wheel to clean up rusty tools, but I can't seem to find it now. Also I had some questions, once the tool is cleaned up how do you keep the exposed metal from just rusting up again? oil? Does anyone have any recommendations for degreasing and cleaning or polishing a tool box?
Rusty tools:
Electrolysis or a fine wire, wire wheel.
Rust on Chromed tools; SOS, pad or oil and 000 steel wool.
If any water was used, WD-40 to displace any water I might have not been able to get out.
Greasy tools:
Simple green, if that didn't cut it carb cleaner,
Tool box:
Simple green,
If ground in; rubbing compound.
Rust preventative on non chromed tools:
Gun oil (made for the job...)
maven
Impact sockets and non chromed wrenches, Spray Nine followed by a spray of silicone. Unplated pliers get the silicone spray too.
Greasy tools always cleaned with SprayNine. Sometimes BrakeClean
Box wiped down with Honda Polish. (now known as Original Bike Spirits spray cleaner)
crewchief888
NW indiana
every couple years i pull all my tools out of my service truck for cleaning/degreasing.
clean mineral spirits in the parts washer,
brake cleaner,
the box gets pressure washed inside and out.
2 months later it pretty much looks like i didnt clean at all. :headscrat
in the garage all i need to worry about is dust on my boxes, tools get cleaned up with brake cleaner
:beer:
LSU
Someone on here posted "Pimp Juice"
It is 1/2 WD40 and 1/2 Automatic Transmission Fluid.
I made some up and clean up a whole bunch of tools and boxes with it.
I was happy. Doesn't smell bad and wasn't tough on the hands.
86k10
Colorado
I use lemon Pledge for my KRL761. It sure does look pretty when done. I got the idea from an old co-worker who use to use that on his tool box.
slob
Bronx, NY
At work we have this concentrated purple soap, possibly from Zep. Then everything gets a thin coat of Trizol penetrating solvent.
OilyRascal
El Dorado, Arkansas
ZEP sells an Industrial Heavy Duty Degreaser that my local big box hardware store sells in 5 gallon cans. I use it with extreme caution (absolutely no skin contact) for heavy oils/grease on SOLID STEEL tools only. It WILL remove paint from painted surfaces, it will react with certain metals, it will affect the appearance of woods, and it will degrade plastics.
vga
I use tri flow chain lube to both clean and wipe down each tool. Tri Flow keeps corrosion away also as I get a lot of rain( not this yr) combined with low temps where I live during winter months.
BWS
Mnts of Va
Our bxs are so old,I'd be affraid of cleaning them?You know,that whole....antique-patina-don't F**K with it...notion.
But posted a thanks on the "pimp juice".BW
slob
Bronx, NY
Yeah. Turns out it's some other company's version of that, diluted. We use it on plastics all the time with no effect. Didn't do anything to my hands that a little cocoa butter couldn't fix, either.
lowbucktruck
Foothills, Northern California
I use awesome from 99cent store works great
Ditto! I also use "LA's Totally Awesome Orange cleaner/degreaser" from the dollar store. You can dilute it just like Simple Green, but its more gentle (will not remove/damage paint finishes) like Green will. And you can buy it in the gallon refill jugs for a buck! Simple Green is a bit too strong for wiping down your toolbox, hard on the paint job.
GRX
MD
Spray on furniture polish works very well. There are many high priced products out there, simple is often best. I wipe my tools with it and use as a rust preventative on engine parts often. Sold an old Pontiac 389 crankshaft a couple months back. We opened it and the crank still looked new as the day I polished and bagged it over 10 years ago. Good old Lemon Pledge.
