I have a 30' RV and 30' sailboat. Both are about 11' high. I also want to put in a car lift and park a car in there.
What size are we talking about, 45' wide, 40' deep and 12' high? I'm not sure how high the ceiling has to be to accommodate the typical car/truck on a lift.
I don't want a **** load of doors. They're expensive, they leak air and I don't need drive through access to all the space as the RV & Sailboat are in for storage. If I had a fair sized sliding door and put the RV on one side and the Sailboat on the other I think I could get away with a sorta large door in the middle. That would put the work area in the back in the center.
I'm going to Morton buildings Saturday to discuss this. I'm open to almost anything due to my abundance of ignorance. I know what I have to put in it but that's about all...some detail construction ideas.
I want a 6" rebar floor. That should support any any lift. I want Perma-Columns, I also think it would be an ok idea to only put windows on the ends above the ceiling height. I don't want any windows at ground level for security reasons and the fact the light would mostly be blocked by the RV on one side and the sailboat on the other anyway.
Also, the roof pitch. The higher the pitch the better it looks but the more it will cost. Since the side walls will be so high I'm not sure what roof pitch makes sense.
I guess I'm just talking out loud to get some feed back on what questions I should ask.
