How often do you use your Ratcheting Screwdrivers?
uart
Australia
I've got a handful of bit drivers that have come with various bit sets that I've bought over the years, but I seldom use them for driving screws as I mostly prefer conventional "fixed" screwdrivers. So usually I only use them for the occasional special types or sizes that I don't have in a fixed driver.
The other day however I had a bunch of PH2's to drive in a really awkward spot, all a tight fit and all about two inches to drive. Because of the awkward location I had to twist and contort into a really uncomfortable position, and using one hand to brace myself, could only just get access to the screw with the other hand. I tried but couldn't get enough purchase on them to use a powered driver, but I could manage (albeit slowly) with my regular PH2 driver.
I could have got the job done with the fixed driver but it was slow and agonizing. So I switched to a ratcheting bit driver and couldn't believe how much easier it made it. Just the fact that once I eventually got the driver into the awkward position and got a good grip, that I could just hold that grip/position without having to release it until the screw was done, it made all the difference.
All I can say is wow, after that experience I'd definitely say that a ratchet screwdriver is something every toolbox needs. :) I cant believe that I've had this tool for years (bought it for the bit set that it came with) and only used it for the first time now. :eek::eek:
MoToys
Long Island, NY
Definitely not something I grab for every use but it has it's place and gets used at least once a day. I find it's best for work that really needs 3 hands or cylindrical lock installation (makes putting a double cylinder deadbolt together a breeze.)
BUCKNERBUCK2
I bought a Snap On ratcheting screwdriver set about 10 years ago when I started as a tech. The set was $60 I think. Its been my go to tool for auto and house work for the last 10 years. I take it with me on vacation. If we go out on our old boat, its with me.
metaleltr
Western Ohio
I have a Snap-On one in my tool set a school. It typically only gets used if I need to use bits from the accompanying bit set. It's a nice screwdriver, but I just don't drive that many screws.
This set with case of bits
Snap-On Ratcheting Screwdriver
crewchief888
NW indiana
i rarely use one at work, i have a long t handle set with bits.
at home a SO ratcheting screwdriver is the one i usually grab for "round the house" stuff.
:beer:
BUCKNERBUCK2
It is but it has a pretty large head as far as ratcheting bit drivers go.
Yeah its one of the tools I would spend a chunk of money on and never use it. I have a few ways of low profile screw access, the blue point one just flips between Off-On when you try to use it. Very frustrating.
GirlnAgarage
Texas
It's my go to Phillips. It's tedious working with one hand. Ratcheting eliminates the need for using my off hand to support the driver.
re: large head
Yup, there are times I cannot use it because the shaft it too big to fit into the given space. I go to a standard screw driver then
MoToys
Long Island, NY
tbobbo
Bismarck, ND
I have the snap on that has the removable shank and i use it everyday. I have a few different shanks and it gets used everyday. I love the 1/4 socket shank, I gave all my nutdrivers away because of it.
Scout Driver
South Dakota
I use mine when doing interior work or electrical work. Here in the rust-belt, a regular driver is usually needed to crack screw loose that are exposed to the elements.
Scott
Obie
Indiana
Actually replaced all my Craftsman Professional screwdrivers at work with a Mac 49pc. Ratcheting Screwdriver set (SPMR49B). I'm not happy that it's an import, but I got over it when I handled it on the truck. It's kind of funny that of the very few import (asian) tools I own, most are Mac. Very nice driver though, and a good selection of bits.
sdguy55
Pierre, SD
Very rarely do i come across the need for a scredriver as of right now but you have to have a set because every mechanic needs a set in his box. I have the snapon ones like listed above and i also have a cheapo 40 piece fixed screwdriver set. I find that if im in a tightspot for a screw (like dash speakers) i find it way more comfy and easier just to use a 1/4 drive ratchet and socket with bit
BobsurUncle
Tracy, Ca.
I use mine everyday. I have two tools I carry with me all day for 8 hours. My red and black Snap On ratchet screwdriver with #20 torx, and a 32oz Snap On dead blow mallet.
The only time it failed was when l drop it 15' and exploded the guts out of it. Found the parts, put it back together and it's been just fine. That was 2 years ago.
DrkMtnDew
I like my ratchet screwdriver for times when i have to be away from the shop. it has a variety of bits that i might need without having to go back for another driver. I've got the standard 8'' and one that is ~22'' with a red hard handle.
Snap On Ratcheting Screwdriver
bsaint
Manchester, CT
I used it a lot when I worked on Japanese equipment. Now Im back working on italian equipment and they use all hex so I just use my hex keys.
bgott
Houston, TX.
I use mine fairly frequently. I use 'em for my torx bits. It's easier to carry the ratcheting screwdriver set to a job to match up bits than it would be to carry three or four torx drivers.
Sam B
Honestly, almost never nowadays :lol: I used to all the time, but once I got my cordless screwdriver, the ratcheting almost never gets used...
Wrenchette
On the wrong side of the tracks.
I used to use mine a lot...But I lost it somehow at Budget Wrench in Belton last week, still pissed at myself about it. Was an SO Dale Earnhardt edition that I'd had for over 15 years, someone had a good day because I sure didn't have a good one as far as tools were concerned...Lost the screwdriver with a Mac bit, broke my T40 Mac tamperproof bit getting a Tuned Port Injection unit for one of my trucks, broke a 10MM flex head GearWrench...:willy_nil But that's the breaks...Literally! :eyecrazy:
bibman
NEBRASKA
Daily, I have an orange snap-on that I have used for 18yrs...I swear by it. I also have a few craftsman I use. I wish I still had the one that had silent ratchet mechanism... not sure how it worked but would feel no resistance when ratcheting.
illmatyk
Yigo, Guam
Brucegbombara
Long Island, N.Y.
Why do the older SO ratcheting screwdrivers have dents in the shank at the bottom where the bits go? Anyone notice that? I have several old and new and all the old ones have the same marks.
shoturtle
Frankfurt AM
I have them for work, but I rarely use them. The motion is a bit awkward. But at times they do come in handy.
canuckian
East coast of Canaaada
Just a wild guess but id imagine it was part of the manufacturing process. Can't think of any way that little mark would help in using the screwdriver.
bgott
Houston, TX.
About half way down? It looks like a squeeze point to retain the magnet.
magova1104
USA
I have a Snap on ratcheting with removable shank. I ordered a special case from Chicago Case Company. I have phillips, flat,torx,magnetic bit holder, 1/4 drive socket extension, angle bit driver, etc, In addition with some other tools in that case. Its about 12"x8"x2:. With that case, I can take a car bumper and headlight assemblies out, remove fenders,dashes, install a sound and security systems,home electrical and more, thanks to the RATCHETING SCREWDRIVER.:beer:
scott917
SE Texas
My very first Snap On tool I purchased was a ratcheting screwdriver. It has a neon green handle and I got it in a promotional thing with a insulated mug with a Snap On calendar ******* it. This would be the Summer of '90? I still have the screwdriver and the mug, never used the mug. I don't have the original box it came in, or i would put them back together and put them on a shelf. It is my favorite go-to driver when I need one. I have since bought a new one in orange and am planning on retiring my green one. It is still in mint(ish) condition, but I thought I would give it a rest and use my new one that I plan to beat to hell.
SuzukiGS750EZ
I really like the few different sized ones my grandfather has with the bits in the top of the handle. My uncle bought me a red handled craftsman one for christmas and i use it a lot at work. I somewhat like it better than the snapon one in terms of smoothness and comfort, but i dont like how you store the bits.
wreckercologist
cyber-tool hell
I use the hell out of mine, but they are T handles.
I swapped the shanks between these two, as that better suits my needs:
http://buy1.snapon.com/catalog/tools.asp?tool=hand&Group_ID=681985&store=snapon-store
While not exactly screwdrivers, I do use them with bit holders some.
This is my second one of these:
http://buy1.snapon.com/catalog/item...roup_ID=675084&store=snapon-store&dir=catalog
Worth every dollar.
I have one of these at home (model# WRST4). It is the same as the one above, but lacks the knurl on the shank:
http://www.snaponindustrialbrands.com/DSN/wwwsnaponindustrialbrandscom/Content/PDF/SNCAT1_289.pdf
Disassemble, relube with Lubriplate #105, and reassemble. :3gears:
