Mmfh
MEMBER EMERITUS
Hey guys,
I may have just got lucky and got me a 75,000 "New" BigMaxx for next to nothing, but it was originally setup to use propane. I want to use NG.
Helped a friend install this one in his pole barn, he doesn't think its large enough for his place and is looking for something much bigger. I will end up with the one we just installed, and only used once. It has about 4 hrs run time.
I found online a kit that looks to be just 4 or 5 jets that you change, different size hole for the different type of gas. Some guys I read say that the Gas valve is different and maybe even need a regulator?
Anyone here have any experience with doing a conversion, and can confirm if just changing the jets will do it or if more is necessary to make it work.
Is this something I should get excited about or just let it go?? Or should I call the manufacturer and see what they say??
Thank You!
Mm
Thank You!
Mm
