On relation to ratchet length, how much torque can one get?
robertsolson
I was told once that with a 9 inch ratchet, you can get about 35 pounds of torque. And I have read that you can get 1000 pounds of torque from a 40 inch breaker bar. Is there an equation to estimate the relative torque for a length of ratchet?
Givl Reggin
Hawaii, USA
Pushing or pulling? Constant pressure with a smooth motion or jerking? Lots of factors... I don't know if it would be possible to come up with a rule-of-thumb.
SMKS
USA, planet Earth
Well, you'd have to exert around 300 lbs of force on a 40" bar to equal 1000 ft lbs (if my math is correct). That's possible, but it would be pretty difficult to do.
blacK20
I don't understand what you're trying to ask. The amount of torque you can get is all relative to how hard you can push/pull on that ratchet. (up until something on the tool breaks of course). As well as the length of the ratchet.
alvoski
Lenght of ratchet in feet X force applied = torque
Or
(length in inches) /12 inches X force applied = torque
Anyone please correct me if I'm wrong. I haven't done algebra in a few years
shampoop
SW Washington
it's all about how strong you are + how long the lever is + how much power is stolen by the tool flexing.
you can definitely exert a lot more than 35 ft/lbs with a 9" ratchet.
Olafur
Iceland
Yes, and a simple one.
Torque = "length of the ratchet" multiplied by the force applied.
Length of the ratchet - meaning the distance from the center of the square drive to the "point" where center of the force applied (i.e mid handle).
It follows, for the same force; if you double the length of the lever (ratchet, breaker bar) you double the torque.
