Well water filter?
Chris 50
LaPorte IN.
There was a post here some time ago that I can't seem to find about filtering the water supply in the garage. I have pretty good well water, but I'm trying to prevent water spotting when I wash the vehicles. Anyone recall the filter or the thread?
I'm still in the construction process of my new shop/garage and will post some pics soon. Thanks.
kbs2244
I have lived with well water for 50 years. Never had a filter.
I think your spooting problem may be more do to hard water than anything a filter will take out.
A water softener devoted to a garage seems a bit of overkill to me. Is you garage going to fed from your home well? If so, then you can put a softener in the house for the lady and have soft water in the garage also.
Mr. Welsh
I recall a thread where a couple members posted pictures of some filter system, but I can't remember the thread or the brand. I know they were black vertical cylinders...possibly with yellow brand marking on them. It might be in someone's build thread but I cannot remember which one.
Dragster Racer
Morrison, IL
Agree with what was said above. You can filter it all you like, but you won't get all of the minerals out and the hardness will cause spotting. I am struggling to justify a softener for my shop right now. That is the cure though.
W-Cummins
Iowa
Those are in my building thread listed below (starting at post #62, at least I think that's what your refereeing to) They are Kinetico systems and are very nice but over priced. I use a model 100 to remove my hardness (65 grains hardness) And I have a Kinetico R/O system installed too. You would have to have very large RO unit if you were going to wash cars with it... Remember too that if you have hard water the softener will replace every grain of hardness with a grain of salt....
William....
JohnK007
Downers Grove, IL
I'm on city water, not a well, but this is the set-up I have in my basemment. The first cartridge filters particles (I think it's 5 microns) and the second set (the blue one) is an activated charcoal filter to remove odors and improve taste. It doesn't "soften" water per se, but when I change the filters you can tell the difference when you take a shower. I installed these when we went from the village-owned wells to Chicago water. When on the old wells I had a softener. Now this is all I use.
Sorry about the dust! :eek: You can see on the left the yellowish tinge. It's about time to replace the filters. Normally I can change the left one twice before I need to replace the right one (charcoal).. Each tube holds two filters.
Jaguar Fan
Park City for Ski Season; Las Vegas for Poker Seas
William....
I have a water softener for my house & garage, and a "Reverse Osmosis" system as well.
When the wife washes dishes, she still gets water spots -- but these water spots are not "hardness" (typically calcium carbonate in our area) but rather are "table salt" type deposits that brush off prettty easily. So, when she washes silverware or crystal or wine glasses or whatever, she gives things a fast rinse from the RO water dispenser -- then when things air dry they are spotless.
A typical residential RO system has a holding tank of about 3 gallons -- enough to supply people with drinking water. You could wash your car with soft water, and then give it a final rinse with RO water -- but you would probably need to get a unit with a much larger tank - say 10 or 15 gallons.
Some soft water companies sell systems that do not use salt - instead of ion exchange (where sodium ions are exchanged for the calcium and magnesium ions in the water) they rely on magnetism or other techniques. Personally, I do not believe they really work: see for example http://www.chem1.com/CQ/
C
Chris 50
LaPorte IN.
Those weren't the posts I was referring to, but good info though. After seeing some of your opinions on this, the filter I had read about may have been to good to be true. I seem to remember it as a simple in line type that was relatively inexpensive and used for my intended purpose. My water is good enough that I have yet to even hook up the softener after being here a year. (My wife is pushing for it though.)
I plan on T-ing off of the well located between the house and the shop, so it wouldn't be run through the home system.
anojones
I came across what I think you are looking for when looking for a water filter for my garage. There are some home made ones and I found this product- I don't know anything about it but it sounds like what you are looking for.
http://www.spotfreeh2o.com/
C
Chris 50
LaPorte IN.
Cool. That's more what I had in mind. Now I guess the next logical question would be does anyone have feedback on using one of these things, good or bad?
FunfDreisig
The real answer to water spotting is rain water.
Every garage has a roof -- some of us use it for something besides keeping the stuff inside dry :)
Funf Dreisig
Kevin54
MEMBER EMERITUS
Urbana, Ohio
My dad has always had black cars and when it was getting ready to rain or a light rain is when he would wash the car, then pull it back in and dry and wax it. He swore by rain water for rinsing cars.
