Turning Corian on the lathe
kyrbz
midwest US
rlitman
Long Island
It sure does. That stuff is a dream to machine, and there's no wonder it's a favorite of many pen turners.
smschriefer
Yorktown, VA
Great work on the knobs and even better work on the Isetta! I just read every post on the car restoration that is in progress. Your attention to detail is insane - in a good way. I can't wait to see the body mated to that impeccably restored frame!
K
kyrbz
midwest US
Thanks for the compliment!
Trucky
Is the tool just brazed carbide or is a PCD tip on there as well? They look rather good by the way.
K
kyrbz
midwest US
It's a carbide insert that is mounted upside down in the tool holder of the lathe duplicator. I have the duplicator installed on the backside of my wood lathe so that I can turn freehand normally from the front.
The carbide insert leaves a little bit of a grooved surface in the Corian, so after the using the duplicator I would go back and do a little final shaping and smoothing with a skew chisel by hand before sanding and polishing.
mtnkrake
The restoration of the chassis looks real good. I can't wait to see it with the body on it.
Beaumont67
St. Thomas, Ontario
kyrbz - great job on the Corian turnings and nice web site, as well.
I would like to see an overall photo of your lathe, if possible.
- looks like you have a nice setup
- is it a wood lathe with a 3 jaw chuck & variable speed DC motor, or a metal lathe ?
bimmer1980
York, PA
that was quite interesting and entertaining to read through your whole blog. I didn't have time to read all of the BMW literature you had posted, but I may have to when I have more time.
My twin brother wants to find an Isetta to restore some day.
Nice work!
K
kyrbz
midwest US
My wood lathe is a Vega 1446 with a Vega lathe duplicator that I purchased around 14 years ago. It has a variable speed Reeves pulley mounted on a Baldor motor. I have a Oneway Stronghold 4-jaw chuck and Oneway live center mounted on it. One of the things I didn't like about it was there was no spindle lock or indexing. The close up photo I attached is of a spindle lock and indexing modification I made for it. The tail stock was also a little chintzy so I did some improvements like adding bronze bushings on the locking mechanism and machining a few pieces that are a little more robust with tighter tolerances than what came on the lathe.
NASTYZEN
St-Colomban,Que. Canada
Nice setup and work kyrbz!:thumbup:
What do you use the idexing for, may I ask?
BTW, you may get even better results on plastic using tool steel. You can get a sharper edge than on carbide and you can even shape it to your liking.
K
kyrbz
midwest US
Fluting or making cuts along the length of a turned piece.
