Jason_D
Ever worked on a 2002 VW Passait? What a P.I.T.A.! If you have, I need some advice. This past Thursday I replaced the Tie rod ends on one & then tried to align it. In order to adjust the front camber/caster, the entire cradle must come down/over, AAHHH! That is not the purpose of this post though, this is,,,,,
When setting the toe & steer ahead, I cannot get an absolute level steering wheel. This was/is becoming very annoying. I use both a Hunter & a Beissbarth machine & when I take the car off the rack, all numbers are right on & the steering wheel is perfect, I drive it, the wheel is cocked,,,I went through this 3 times. WTF???
Any advise?
Any advise?
and moving steering wheel to "correct" bad,bad,bad. this only causes other problems in the long run. if you are not going to fix it right, DON"T EVEN TOUCH IT to begin with!!
