need 4 1/2" angle grinder:new h.freight or used something else
1982fxr
Phoenix
i need an electric 4 1/2" grinder for home use, nothing heavy. The H.freight "heavy duty" is like $15 with a coupon, or would I be better off going on craigslist to try finding a used one---and if so, what should I look for?
I don't want to repeat my skil bench grinder debacle, but $15 for junk is easier to swallow than $55. They're all imports anymore, right? Need something that will run with a wire wheel on it
kartracer55
I don't think I'd lump a 15$ HF grinder in the bunch with say an entry level DeWalt @~$60 or so.
You can try it, but I feel like you need a grinder with some serious power if you want to run a cup brush.
Kaervak
Cleveland, OH
Well, I have two of the cheapo 4.5" Drill Master angle grinders they sell. http://www.harborfreight.com/4-1-2-half-inch-angle-grinder-95578.html
Got them each for $10 after coupon. They both work perfectly fine, aren't horribly loud like I was expecting either. The second one I bought vibrates a lot more than the first one, but for $10 it's not the end of the world. They work just fine with a wire wheel brush too. I actually bought the second one to use with just a wire wheel brush so I wasn't swapping cutting/grinding discs all the time.
Monte
Germany
You already had bad luck with a cheap bench grinder (even from a brand name company !!) and now you want to buy a $15.- angle grinder from harbour freight ?
crewchief888
NW indiana
i have a couple of the older orange grinders from HF, they do vibrate a bit, but have been chugging along for 4 years or so.
also have a dewalt and a hitachi.
hitachi is a good grinder for the $39 sale price.
even came with a blow molded case, and 5 wheels. :rocker:
:beer:
lotsoftools
Inland Empire
I'll tell you what, the $20 HF grinder I bought about 9 years ago is still alive and kicking. I use it daily at school, it has been dropped a few times and it just won't quit. I bought a Makita to replace it, but so far I haven't used the new one but a few times.
We sell quite a few Dewalt and Metabo grinders at work. The customers who buy them are replacing them every 1-2 months. I don't think it has so much to do with the quality of the tool, but the abuse they're put through.
I think the most important thing is how you treat them. If you're throwing them down or using them as a hammer (seen that with my own eyes), they just won't last as long.
SIDECAR BOB
illinois
bout a harbor freight one just to use with a wire brish, hated to spend more since I felt I was abusing it with the wire wheel, stupid little thing just wont die, just keeps spinning away. and at 10 bucks or so even if I replace it more often ZI don't realy fel to bad
1982fxr
Phoenix
I don't ''want'' to, but considering I'm just a hobbyist on a budget, I have to consider it. If it's a total ************* I can still take it back. I would expect the name brand stuff to be better, but then again it's all from china anymore (as far as I know).
I've got maybe $25 to spend on one, so it's HF or a used something else. Now, if someone were to come along and say "it's worth you're wait to seek out one of these style from such and such manufacturer...they're indestructible..." I would be listening.
paranoid56
San Diego, Ca
after owning a few good brand names i think i still have one of them. the HF ones have all lasted the same amount of time as the good one. right now i have 1 good one left and 5 HF ones. each one has a different thing attached to it. buy when they at 9.99 each and dont look back. at 10 bucks a pice you can just toss them and get another when it dies
carbon
I bought a red HF one a couple years ago. Immediately, before first use, opened it up and spread the 'grease' (fish goop?) around, as I read lack of proper greasing is a big reason why they fail. I dunno, but it's still going strong.
EDIT: They changed the color. It's this blue one now. Paddle switch is goooood to have.
91bronc300
I have two 4.5 angle grinders, a red HF and a Makita. The Makita is more ergonomic and balanced and has a thermal overload breaker but the Makita and HF both run smooth and have about the same power. I don't think the HF is junk.
Jim Stabe
San Diego, Ca
I use 4 1/2" grinders a lot and have 5 or 6 of them, the oldest is well over 10 years old. All are various flavors of HF all the way from the blue Drillmaster cheapies to the paddle switch model. I have never had a problem with any of them and they all have plenty of power. My favorite is the paddle switch only because the slider switch is a little less convenient to use. I had a Makita before I bought my first HF and it only lasted a couple years. So do you get a lot higher quality by paying two or three times as much for the "name brands"? I don't think so.
theoldwizard1
SE MI
Check eBay for refurb name brand units.
Several years ago, I bought a refurb Craftsman Commercial 4 1/2" grinder for about $20. It's a beast.
ishiboo
Oshkosh, WI
I rarely need an angle grinder, I've had the $10 HF version for the last two years or so. I do not use HF discs.
It's been beat on and borrowed out and no issues. About 8 months ago, I bought the Bosch 2-pack from Lowes when it went on sale, but they're both just sitting in my toolbox until the HF dies :)
It's the el-cheapo Drill Master too, not the $5-higher version.
AB6DO
I have been using Harbor Freight 4 1/2 inch grinders for 15 years. Over the years I have collected about 6 of them for convince of not having to change the tool. I have yet to have one fail. My original Makita 4 1/2 inch grinder died about 5 years ago. I just trashed the Makita and never looked back. The HF grinders have enough power to run any tool I have attached to one.
Philbert
I still have my B&D Pro 4 1/2" Grinder, it's like about 20 years old now. I haven't used it much in the last ten though. Now that I'm no longer in the
trades a lot of my tools have been parked in the shed. But I still go in there
and oil them up every now and then. Just keepin them ready when I got that project to do at the house.
AB6DO
boro_boy70
Whitesboro(Utica), NY
I bought the same Bosch deal, but my orange HF cheapie just keeps going strong. Had it 3-4 years now and it still runs like a top, can't go wrong for less than $20.(forgot what I paid for the thing)
eljefino
Had a local surplus store china-special last eight years of infrequent use until I overheated the motor and the windings let the smoke out. That was worth the $10 to watch.
Got a northern tools one, the right angle gearbox thing failed fairly quickly. Still have both sitting in a dusty corner in case I want to make one from two. They say "oil" the gearbox but that spins so fast I don't see it sticking around.
HF $10 model is my third and doing fine.
monster1
They are all made in the same place but the difference is in the quality control. I buy my power tools from HD and never had a bad tool out of the box. My neighbor buys the hf equivalent which often looks exactly the same except for color, and he constantly has to return stuff.
805gregg
Ojai, Ca
I wouldn't buy a $15 grinder, but I do have a very nice Milwaukee 4.5" that will out last me and my 21 year old son.
fflintstone
MOFnowhere Mi.
If you are going the HF route buy the more expensive 6 amp paddle switch model. It is worth the extra $10.
Or spend $50 and buy a used Metabo or an older USA Milwaukee.
