Blocking the gap around Garage Door?
jake26
In my garage makeover, I am learning all kinds of stuff from electrical, insulation, plumbing and plastering (hence it seems to be taking forever). I learn as I go and have to thank everyone on this site for answering my many questions. So here is another:
My garage door has air gaps around the perimeter that lets in cold air and light. I never cared before until I installed an electric heater so now I would like to limit the heat loss if possible. Are there any products that will block that gap but still allow the garage door to move freely?
Chaz
Missoula, MT
There is weatherstrip available for just that. A garage door supplier can fix you up. They work well.
Milton Shaw
I have the brush type on my door it seems to work good. Got it from a garage door dealer.
trbomax
starvation lake,mi.
I had that problem with the doors in toledo,and Ive noticed this year my door up here is showing a gap too. What I did was to get some of the self stick black 1" wide weatherstrip that is used to gasket truck caps and apply it too the trim between the face of the door and the opening frame. You must run it above the door opening a few inches so that it doesnt catch the bottom edge of the door when it goes past it. I also found that after one season it came loose but was easily reattached with 3-m super 77,so when the weather warms up and I put the weatherstrip on the opening here, I will spray the frame with 77 before even putting it on.
Jbullfrog
Avoca, Iowa
I use garage door weather strip. It is vinyl with an 1-1/2" wide 1/4" thick trim that screws on and an 1" flexible strip that sits against the door.
J
jake26
Thank you for all the suggestions.
I will need to go shopping to check out these options. I assume they all go on the inside frame of the door opening and I would have to paint the area before installation. Hopefully, I can find some photos or instructions so I can see the process.
BeachBum2012
So Cal
I just purchased the White Vinyl kit that Wingnut posted as well as a threshold. Looks like they will both be quite simple to install. Guess I'll find out Saturday.
J
jake26
Opps ... I take that back. Of course the weather stripping will need to go on the outside to keep the weather out.
I know my garage already has a stripe along the outside door frame (it is only 10 years old) so I may have to remove that product and install a new tighter fitting rubber product.
RKA
To piggyback on the original question...I'm curious if anyone has added brush seals inside the door to supplement the vinyl seals outside? I've seen one person mention this in the Heat/AC forum, but wasn't sure how effective it was (purpose is energy efficiency w/conditioned air space inside). I have relatively new insulated doors with fresh vinyl seals installed around the perimeter but there is a good deal of air movement through that gap even though the seals sit flush. I could install some brush seals on the inside of the frame, but would rather not go through the added trouble and expense if it's not going to do much to impede the air movement.
Tom in Seattle
Sammamish, WA
Not trying to hijack the thread... but are there any products that would help seal an uneven floor under the door? For whatever reason my garage floor is bowed up in the center so the 2-car garage door hits in the middle and thus leaves gaps under the door at the sides. It seems the rodents like to visit my garage in the winter and I'd rather not have critter visitors.
shawge
Portland, OR
@ Tom_in_Seattle: I have the same issues with my garage floor as well. I installed a retainer and bottom seal similar to this:
The center squishes flat and the outer edges seal well.
gatewaysysop
Arizona
Check out this thread, a pretty good amount of info in there.
I did the vinyl weather strips outside AND the brush-style stripping on the inside of the garage, it's a great combination (and cheap!) and works extremely well. I'm super happy with it. :willy_nil
Post #20 in that thread has a picture of how the brushes look installed on the inside. Again, this a great setup and I can't recommend it enough. :rocker:
J
jake26
Very cool! I think this may be what I need. Thanks for the link!
diggertodd
Athens, Illinois
Even as tight as I have my door sealed, in the dead of winter, I use 6 wedge door stops from the dollar store and wedge them between the track and the door to push the door against the seal. works great
RKA
Awesome! Just the feedback I was looking for. In case anyone doesn't read completely through that thread, the standard seals from sealeze were twice the thickness of the residential and if you call them, they will mail out samples if you're not sure what size will work best for you.
karl1672
Lakes Region, NH
karl1672 can you post a some pics of the install.
Here's some pictures. Garage door openings in FL are usually a little different in that the door closes behind the garage slab, rather that on it.
First, I installed a new bottom seal kit from MD, and then the Tsunami. Also had to adjust the force on the garage door opener.
mpire
Florida
I have the seals on the outside but the garage door tends to move back and forth in the tracks more than a quarter of an inch.
So I also installed brush seals on the inside.
Still don't have a good seal.
AndyL
Vancouver
Mpire- straighten up that top section (notice its tipped out?) Then re&re the weatherstrip, install it tighter lean on the door as you install, to push it back. And fix that corner :D
santagary
Pagosa Springs, Colorado
I cannot use those because of freezing conditions in coloado...it would rip off upon opening it! :sad:
AndyL
Vancouver
Yes you can we use them in calgary all the time... chinese rubber will stick, but most will shed the ice just fine
mpire
Florida
Either my door is curved or the concrete is curved, either way it doesn't seal in the middle.
I am not sure what to do next.
AndyL
Vancouver
How big is the gap - go measure... Ive got an old door guys trick that'll fix you up nicely...
mpire
Florida
My gap is only about a quarter of an inch.
But the issue isn't the seal isn't flat on the ground, its that the door bows out or the concrete lip bows in.
AndyL
Vancouver
There's various grades of weatherstrip... That roll stuff, probably ok for warmer climates, I wouldn't use it in the snow belt... Even up here, I take issue with the various grades we see... Triple seal (sometimes called arctic grade) is the only way to go - but everyone claims to sell it - very few really do, perhaps I should go take a picture to show the differences... I'm not a fan of the brush type personally, it doesn't actually do anything to stop air infiltration.
Mpire - is it bulb rubber underneath or is it one of those damn foam strips?
AndyL
Vancouver
Left - is steelcraft (but it's commonly found with various manufacturers)
Center - Arctic grade - note it's a triple seal, one between the steel and the jamb, 2 to the door...
Right - typical PVC stuff (this is wayne dalton stuff) You get a true thermal break - it leaks less than the steel on the left, as it typically bends and sits flush (and pvc actually does have an R rating)
A1an
Tampa, FL
Thanks for the comparison photos. That triple seal looks great but probably overkill and impossible to find down here in FL. The PVC seems superior to the roll but I am just having a difficult time finding it locally. Lowes or HD show it in stock on the website but when you go to buy they have maybe 1-2 strips in a color no one wants.
DustynF
[Still don't have a good seal.
I didn't quite have that big of a gap on the sides but what I ended up doing is drilling the rivits on the side rails and then adding bolts to move the rail closer to the jamb. My doors are tight on the weather stripping now. The bottom can be fixed as well, either add a rubber threshold or repour. I repoured my floor because whoever poured the floor initially put a 7 inch pitch from left to right. :willy_nil
mpire
Florida
I have the standard loop type garage door seal on the bottom, but to make it stiffer, I stuffed some pipe insulation inside it to try and make the seal better.
It didn't help.
So I have to come up with another solution.
mpire
Florida
What I need is a seal that is wider in cross section on the bottom and not just taller.
AndyL
Vancouver
Mpire - yeah pipe insulation won't compress where you need it to - and provide substance where you need it... as pathetic as it sounds - try stuffing some old Safeway shopping bags (yeah plactic grocery bags) in, its an old door guys trick; works better than any 'manufactured solution I've ever found...
langss
California
I used this on the exterior door trim to seal the edges:
http://ddmgaragedoors.com/parts/part/STS-210WH.html
Lowes site *****, I actually bought this at Lowes in 8' sticks.
I bought this at Lowes as well. I'm using it on my front and back entry doors to seal the gap between the door and the threshold. The doors are longer than the standard 36". I also ran two lengths along the bottom of my Garage Door. It seals really well.
