Mig Welding Questions
Schmokie
Leesburg, VA
I have a Millermatic 211 and I love it, being a novice welder I have two questions. The first, can I leave my shield gas gauge turned to the proper psi when I am done welding and have turned off the gas and purged my line? The second, has anyone ever made a folding welding table?
:dunno:
kc-steve
Kansas City
Congrats! Sounds like you are starting at, or near the top of the line. I'm green with envy just in time for St. Paddy's day. :)
I'm a fan of making my own equipment and stands, but it's hard to beat just buying an older Black and Decker Workmate and converting it. The older ones have some cast iron legs so are fairly substantial. With the current prices for metal stock, it's hard to beat when considering the money situation.
BTW, welcome to the board. :)
Steve
sberry
Brethren, Michigan
I don't do anything but turn off the gas bottle, I make it a habit,,, switch to the machine, then bottle on, bottle off before I turn switch off, if I am interrupted I never leave the gas on this way.
mordantly
the regulator will get worn when left on one setting it's entire life. no big deal really... unless you want a lower cfh/psi from it, then it won't be accurate. i'm **** about all my regulators being backed out when not in use. since it can be months+ before i get back to using it.
Schmokie
Leesburg, VA
Thank you all for the info, I currently have a workmate table that is just too small. I have replaced the wood top with a metal one but still need more room. I have gone to Welding Web and felt like a kid in a candy store, the problem is that there are so many choices!! I am going top back my gauges out and purge my lines, just seems right.
Thank You all again!!
Schmokie
Leesburg, VA
Thanks for the welcome, I did a bit of research when I bought my welder and actually got it for $1600. That was the welder, full new bottle, spool gun, consumables kit, cover and cart. I should have passed on the cart, it's pretty cheesy but everything else is great, can't wait to get into aluminum.
SINISTER
Long Island
100% helium required for aluminum
Please don't give the man false information. I am glad you said that though because now I can properly inform him on shielding gas for use with aluminum.
First off Helium isn't required. Lets get that out of the way.
Helium is usually used to get a hotter burn. The thermal conductivity is about double that of the other gas that is great for alum. (Argon) This allows you to have greater penetration, wider spread, weld thicker pieces.....This is good but it also allows for burn through especially when new to welding.
Helium also produces a burned looking bead. Which can be removed with a wire brush ect.
Helium is also more expensive, less dense, and requires a higher flow rate than argon. You will find yourself going through it faster, until you learn you can go faster with the gun.
Now Argon is great for welding thinner types of metal. Its produces a narrow spread, its a little more pourus, and the beads are generically brighter and shinier. Keep that in mind when doing production work.
Any type of structural aluminum should be done with helium or a 75/25 mix of helium and argon.
You can mix these two gasses no problem, the more work you do you will realize which mixture works the best for you. Remember argon is cheaper, if you are not doing alum chassis, certified alum roll bars/cages...then you probably dont need helium, and/or you can adjust the amount of helium in you mix to help if you weld thicker materials.
I prefer argon as its cheaper I get more for my money, it produces a cleaner brighter weld, and I don't have to switch the bottle if I want to weld some steel pretty quick. Welding steel with a pure argon mix isn't recommended but can be done if you need to do something quick where strength isn't a concern. If you have ever tried welding steel with helium you get erratic patterns and its almost impossible.
I do a lot of side work on custom cars, intake piping, catch cans, radiators, inter coolers, reservoirs ect. Helium is not needed, I have a smaller bottle, that I can go out and fill with 100% helium if I do a certified cage, but because of the price I have only done one before.
