Is the wire in a metal jacket? The only two wire I've seen is BX cable.
Could also be 'old' plain 2-wire cable (IIRC, some of the 'old' rubber/tar cloth-covered cable that disintegrates if you look too hard at it or sneeze in its direction was just 2-wire), or it could maybe be two wire inside metal conduit (with the metal conduit serving as the 'ground'), or it could be
really old knob-and-tube type (completely separate lines, sometimes snaking off in completely different directions and just coming back in the general vicinity of one another at the outlet/switch).
http://en.wikipedia.org/wiki/Knob_and_tube
If the existing 2-wire (insulation condition mostly) is in OK condition, leave as-is and maybe add the GFCI outlet(s) as desired for a little addition safety. IMHO.
If the existing wiring is showing insulation degradation, then replace and 'upgrade' the wiring itself and possibly also the infrastructure and layout of the wiring 'system' (our society now is a lot more dependent and used to electrical devices, as opposed to 'way back when' where an entire house might have had a 'whopping' 30 or 60 amp service and just a single-digit number of different circuits for the whole house). Possible new service entrance and meter (for the addition ampacity), possible new panel (for the ampacity and the total number of circuits all over the place), new wire and new circuits and new outlets and switches and whatnot. More $$$ obviously, and you almost always then have to bring the electrical system up to completely 'current' (no pun intended) electrical standards and Codes (breakers, circuits, wires and cables, outlet and switch amounts and spacing and locations, and whatnot).
