Refurbishing Buck Rogers Ray Gun Drill
ndnchf
Fredericksburg, Virginia
i've always liked the old aluminum cased power tools, especially those of the 1950s that had that really cool look to them. I picked up this drill a few weeks ago - it was a $10 clunker. But I was drawn to the Buck Rogers ray gun styling. The name tag is missing, but its a Speed Way model 400.
I didn't have much to lose so I dove into it. The case was well battered, but no major damage. It did have some stripped threads, broken and frozen screws. Here is what it looked like when I got it broken down.
Once inside I found the wiring was scary, old nasty grease in the gear box and mismatched screws. When I got the armature out I found that the fan blades had been broken off long ago :sad:
I couldn't do much to repair the fan, so I cut off the remainder in order to keep the armature balanced.
I thorughly cleaned all the old grease from the gear box and all other parts. I installed a new 3 wire grounded power cord and found a convenient location to attach the ground wire with a 6x32 screw.
While it was apart I wet sanded the outside of the case with succeeding grades of sandpaper up to 1200. This was followed by Mothers aluminum polish and elbow grease. I knew I could not get all the dings and dents out, my goal was to get it cleaned up and bring some shine to it. After polishing it, I regreased the gears and put it back together.
The end result is not perfect, but for a $10 clunker, it turned out pretty well. It is now servicable, runs well and is safe to use. The only drawback is the missing cooling fan. But I don't intend to use this for long hard jobs, I have other drills for that. But for an occasional hole, I'll pull it out and give it some exercise.
LSU
That's nice.
How would you compare it to a "modern corded drill?
Is it VSR or just full throtle forward?
It looks nice. You did a great job.
N
ndnchf
Glad ya'll like it, its a neat old piece of machinery.
I'll keep my eye out for a donor drill that may have a similar fan. But I need to keep the same length on the fan hub, or make a spacer since it keeps the armature in the correct location. Its a single speed, fwd only drill. Its geared pretty slow and as a result seems to have lots of power.
N
ndnchf
I was building a roller cart for my metal cutting bandsaw this weekend and needed a couple 1/2" holes drilled in the angle iron - Buck Rogers to the rescue! Worked like a champ.
