trboxman
the 1/4" drive has a N-m scale on the opposite side from the ftlb scale.
http://www.harborfreight.com/20-piece-poly-bins-and-rails-41949.html
Item no. 41949
20 piece poly bins and rails. Currently pictured as gray for $9.99, mine were blue for about half that price on clearance. Otherwise identical...
FAIL at any price. Total garbage. The back corners on half the bins broke before I even put any hardware in them.
40pc Tap and Die Sets........EPIC Fail!
Bought both the SAE Link and Metric Link kits to do a quick repair on my sons bicycle after one of the pedal stripped out while he was pedaling it. Since I didn't know whether it would be metric or Standard, for $13 each, I figured I couldn't' go wrong.
It's been so long now I can't remember what size it was now but I did get the proper die to clean the threads on the pedal, it was a fine thread needed. It ended up mangling the threads worse that before I started. The Tap was worthless and actually deformed in the pedal arm. I rescued it with my fathers 50 year old T/D set he had.
At least I only had to work for an hours pay to buy both sets so I don't feel too bad. I wasn't expecting much to begin with but I got even less out of the deal.
Which HF did you go to? The one in Vernon or Berlin?
Berlin. I haven't been to the one in Vernon yet.
I might have to stay out of there for a bit tho....I was looking at the 5 drawer service cart and really really want one even though I have no room for it!
But i'll probably head over to the Berlin store for the parking lot sale for the hell of it![]()
Anybody have experience with this:
Universal Bench Grinder Stand Item # 3184
I've got it. No problems.
I think I paid $20 a few years ago.
Has anyone tried the 100 A battery load tester before? item 90636
Yes - works well, pretty nicely made (above the HF average.) PASS
2 Ton cherry picker with foldable legs: Pass
Engine leveler for above: Fail
3 ton and 6 Ton jack stands: Pass
US General 44" roll cab: Pass
Wooden handled hammers: Fail
Nitrile Gloves (dark blue 50/box): Pass![]()
40ft retractable cord reel - http://www.harborfreight.com/40-ft-retractable-cord-reel-with-triple-tap-91470.html
FAIL
The retracting spring is weak, and the cord tends to bind up in the housing while retracting, so you'll end up with 3-5 feet of cord still hanging out of the reel that has to be nursed back in. I still use mine, it's better than nothing, and it might be worth having at a cheap enough price, but there's got to be something better out there.
MacPherson Strut Spring Compressor Set : FAIL
http://www.harborfreight.com/macpherson-strut-spring-compressor-set-3980.html
One of mine cross threaded the second time I used it and got jammed while on a compressed spring, not a safe situation. The steel seems very low quality.
18 Gauge 2-in-1 Nailer/Stapler : PASS?
http://www.harborfreight.com/18-gauge-2-in-1-nailer-stapler-97524-3795.html
This one is tough. Due to the nailer/stapler design it is very difficult to consistently place a nail where you want it to go, and the piston seems to protrude to far and leaves a dent in the workpiece regardless of the air pressure. That said, it works, and is probably worth the $29 price. But, I wish I had purchased a higher quality tool and probably will in the near future.
I've compressed four springs with that set and had no issues (not that that proves much). I need to ask if you used a lubricant on the threads first. Any of this style can cross thread if you run them dry. I used gear oil (smelly, but it's the best thing for this application), but grease would help too (just don't let it get dirty). Well worth the $10 I got them for on sale.
I have that same nailer/stapler. It ***** as a nailer, but if you think of it as a $20 stapler (sale price), it's awesome.
I actually have the Digital Battery Analyzer (66892), and while I had a contractor testing a few hundred batteries at my work, I compared this meter's results with the results from a multi thousand dollar piece of battery testing equipment (an Alber Cellcorder), and the results were not only within about 10-15% difference from each other, but the consistency and accuracy was surprisingly good for a meter I got on sale for $50. Mega PASS.
Oh, and my wife has a few of the tiny $3 battery testers (96377), and they come in quite handy too. PASS
67415 Multi Vise
I wonder if that cute girl is still working the register![]()
much against a lot of peoples advice, i bought the 1190lb 4x8 folding trailer.
i put it together about 80% last night in about 3 hours. i still have some bolts to install, and fenders, i have to run the lights and add a plywood deck.
i haven't even had the trailer on the ground yet and i've run into a snag. the 4 bolt hubs are ****. right out of the box one of them was bent. the wheel wobbled probably a half inch total, 1/4 in either direction. i went to the store and swapped it for another one, it's ******* bent, too. i'm going back tomorrow to exchange it one more time and then i'm going to northern tool to buy better hubs. i think the wheel is fine, its just a very weak hub.
i've seen on the reviews that one other person had the same problem. the fact that i've had two in a row suggest that there are a whole lot more bent, people just don't notice![]()
Sounds like the chinamen was hitting the siamese vodka!
I have that vise under another name. For mechanic work, it suits me fine.
