Thorsen Open Frame Ratchets
bowmard
Near Decatur, IL
40+ years ago I bought a 3/8 drive Thorsen open frame ratchet. If I remember correctly it is a model 77.. I liked it because it is a tad longer than the Craftsman 3/8 drive ratchet I had at the time. I still frequently use the old Thorsen. It feelss good with no objectionable slop in the mechanism. I believe the exposed open frame is the reason since it allowed easy oiling. Recently I landed a 1/2" drive Thorsen open frame ratchet off Ebay. It too feels good and works well. It is a supplement ratchet to my '65 vintage Craftsman V series. Now I'm looking for a 1/4" drive open frame Thorsen........
GoodoleBoy
I have one I bought, I was going to sell it..But after using it a few times I like it enough to keep it around.It is also a model 77..
wrenchr
Toss up a wanted thread in the wanted section for that 1/4, you never know!!
wrenchr
If you strike out on the thorsen then wright makes a nice open gear ratchet and they still make them.
KEH
I was given a Thorsen 1/2 drive set as a graduation present in 1961. Used itfor a long time until I gave it to daughter and SIL since it had sentimental value. Smooth, easy to reverse direction with just a flip of the thumb. Later I got the 1/4 and 3/8 drive which are equally good.
KEH
Davefr
OR
Open frame Thorsens are great. They're so compact they can get into spots where others can't.
(example):
woody 73
The Great State Up North
I have used open frames in the past but somehow I always managed to get dirt inside the ratchet and that is not fun; I ended up giving it away just tired of dealing with dirt.
kc-steve
Kansas City
I could be wrong, but I think the whole point of the open frame is for easy oiling and cleaning. I have one too. :D
Steve
bowmard
Near Decatur, IL
Last week I spotted a 1/4" Thorsen 77 up for bid on Ebay so I jumped on it. My luck held to the end of the auction with nobody bidding against me. Today I received it in the mail. It is a nice one that now completes my set of Thorsen open frame ratchets.
Not quite "complete" ; do you have it in 3/4" drive? :bounce:
I have a P&C open frame in 3/4. It's a brute.
plinker
Northern Wi
The Wright's are very nice, I had ordered a 1/2 & 3/8 for a co-worker who like's that style ratchet. 30 tooth and repair kits are available.
Would it be possible to post a pic of the beast
Sure, Here it is next to a 16" long handled 1/2" drive Proto, which is next to a "std" 1/2 " Proto. (The long handed Proto has a heavier walled head than the std.) The 3/4 P&C is 20" long:
I went surfing Eprey for 3/4" ratchets to see if there were any open frame ratchets that size. Only found a P&C 3/4 (Similar to mine but plated) in open frame...
bowmard
Near Decatur, IL
"""Not quite "complete" ; do you have it in 3/4" drive?
I have a P&C open frame in 3/4. It's a brute."""
There were a couple of Thorsen 79Cs and a single early model 79 on Ebay yesterdsay. The 79s are closed head. The seller said the early 79 dated to the 1930s but from what I understand that is too early.
I have a nice, like new Wright 3/4" drive socket set I bought at a pawn shop 18 or so years ago. In a red case, I think the pawn shop owner didn't know what he had for I picked it up for paltry $65. Just a short while before then I paid $35 for a Chinese made 3/4" drive set that gave good service when I restored a John Deere G tractor. The Chinese 3/4" ratchet's metallurgy is suspect but have since replaced it with a Craftsman 44804. I've seen some one of those ratchets that bent when used with a cheater bar (not mine).
