bams50
Early planning stages here, so I'm just trying to get a rough idea on theory:
Building- pole building 50'x120'x18' ceiling height.
Three sections- 50x50 auto resto workshop
25x50 showroom/display area
25x50 apartment with 2nd floor finished
I want to adjust the three sections separately. Naturally, the living area will on average be warmer. The other two sections I would like to adjust down when not in use. If health concerns dictate (i.e. long stretch of inactivity), I might sometimes have the apartment warm, showroom less so, shop just above freezing. Other times, apt. and shop warmer, center not as much.
I am going with in-floor heat, LP gas (no nat. available). I figure the separate zones will allow the most savings. My goal with this build is to never be cold indoors again; although I don't need it hot by any means. We use heat for about 5-6 months here, normally about 10 sub-zero days, 10-15 single digit. I'm trying to allow the most flexibility for the purpose of fuel savings.
Would I want one boiler with three zones; or two boilers, one for the apt. and one for the rest; or three separate systems?
My thought is I don't mind spending a little more now on system to cut utility costs long-term. This will be our retirement home.
Final question- the second floor of the apartment require its own loop to be warm, right? It will be a gameroom/theater room plus guest room/bath. Would that be a fourth zone? Ideally, it could be shut off when not in use, just heating the downstairs.
What do you think?
What do you think?
