Cutting plexiglass?
sizzler90
Idaho
I am trying to cut a piece of Plexiglass. It will have a few curves in it. My first few attempts were not successful. Basically it just melt back together. What is the best way to cut plexiglass?
Jbullfrog
Avoca, Iowa
I have used a Roto-zip to cut panels for toy tractor cabs. You need to be sure the protective cover is still on the plexi or use masking tape so you don't scratch it.
s_ontario
canada
Do you happen to have a plasma machine ? just need sacrificial piece of steel to lay over top
epmills
Missouri
If the piece is small enough, a scroll saw on a slow speed works great, if not, as said, a jig saw. Just remember to take it slow, stop and let the blade cool if needed.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
You won't get a smooth cut whatever you do, but to keep it from melting back together, use a little oil where you are going to make your cut. The little bit of oil will lubricate it enough to keep it from melting back. Unless you are running it it a table saw or radial arm then it will be a little messy. Leave the protective coating on, make your mark, take a bruch and brush some oil on it, and if you have a sander, sand the edges when done. use some coarser paper to sand then finish off with a finer paper.
sizzler90
Idaho
a jigsaw of circular saw works well.
I have tried using both a circular saw and a jig saw. Like I said it melted back together as I cut it. I have a dremel but did not think to use it. Not sure what blade to use with it. Since I do have several curve that will need to be cut, I am not sure a wheel will work.
IDASHO
Moscow, Idaho
Ive heard of people cutting plexi with a plasma cutter...
...seriously. But from what I remember, you have to lay a sheet of steel over it, and cut both.
russlaferrera
Central Virginia
Use a very course blade, carbide if possible (blade is thicker) or if using a jig saw, use a water hose under the material to lubricate the blade and keep it cool
SteveU
Straight cut tablesaw, anything with curves a bandsaw or scrollsaw. A handheld jigsaw would also work but would be harder to control than on a bandsaw or scrollsaw. I have also used a router with a carbide bit to fine tune a piece of plexiglass to fit something. Depending on if you have a pattern/template you could use a bearing guided straight bit or pattern bit in a router but it has more waste/makes more mess than the saws do.
WheelsNT
With water cooling and a fine toothed jigsaw blade, you can get a glass-smooth edge. A water hose works, or you can attach a tin can to your jigsaw with a pinhole near the jigsaw blade so that the water continually hits the blade. Then you just re-fill the can every 30 seconds or so.
sizzler90
Idaho
I am not doubting you, but something about using water and electrical tools just doesn't sound right:shocking:. What is the trick to it?
WheelsNT
It only needs to be a little water, just on the blade to keep the blade cool. Under no circumstances are you pouring water on the jigsaw itself. The water will be on the blade and the surface of the plexiglass and will get on the guide base of the jigsaw, but not up on the electrical part of the saw. Of course, be smart and wear some rubber boots. You'd want to stand off to the side so the runoff isn't under your feet. You can think of lots of methods to deliver the water, the important thing is to get the water directly on the blade of the jigsaw.
PAToyota
South Central Pennsylvania, USA
I've been meaning to try it, but I've heard that you can cut plexiglass or even actual glass by taping aluminum foil down over it.
