rwhite692
Had the Kinetico guy out at the house to check on our water softener, the timer mechanism quit doing it's thing, even after a couple of resets.
We've been in this house since buying it from the original owner, some 13 yrs ago. The Softener setup was new when the house was new, so, 1986-ish.
Anyways, when he pulled out the water softener system away from the garage wall, we found a problem that obviously needs to be addressed....
One of the gray plastic (compression type?) fittings that connect the 3/4" copper line to the threaded male ports on the water softener's bypass valve, is cracked, and has obviously been weeping for a good while. So I'll have to sweat in a new section of copper where it's all corroded.
What the heck are these fittings? I can't recall ever seeing 3/4" plastic fittings like this before.
Puzzler #2, the water filter! Never knew it was back there, LOL. So that obviously needs to be serviced...But, it has no markings on it anywhere to be found, none on the white plastic housing, or the blue canister. Nothing.
Pretty dumb of the manufacturer, not to clearly mark what it is, or the filter part number, on it somewhere. Or, maybe there was a label on it, long ago.
Anyone recognize it?
