Let the fun begin
carb00
Hollister
Ok guys, after numerous nights spent on the forum, I think I'm ready to apply my epoxy. In a few hours I'll be picking up the grinder and starting tonight. I'm applying an epoxy-coat bright red with white, graphite and black flakes. I'll be sure to post pictures of the final outcome. I do have one concern and that's about mixing the epoxy with a cordless drill, should I pick up a corded drill or just make sure both batteries are fully charged?
Syndicate
Definitely a corded drill will help mix it better and you would not burn up your cordless drill. A good paddle bit also helps. There are several types at your local HD or Lowes. Take a couple before and during pics too. We all want to see how ya did it.
C
carb00
Hollister
I finished the first coat last night around 10:30. I walked around and popped the bubbles with air but apparently more formed overnight. :mad: hopefully the second coat plus flakes will cover the imperfections.
LegacyIndustrial
deerfield, IL
Applying 100% solids epoxy over very "open" concrete without a primer can cause out-gassing. Out-gassing makes your bubbles.
A primer is good insurance.
