From slickdeals.
Thank you very much. I will try for the partial refund.
2pc Horn Set: PASS
http://www.harborfreight.com/2-piece-12-volt-electric-horn-set-99911.html
The factory horn on my car sounded like it preferred the company of men, so I picked this set up for 12 bucks. I wasn't expecting much, but they are loud and make my cars horn sound like a '77 Lincoln.
It wasn't a direct replacement since I was replacing one horn with a dual horn set, but it was an easy install. I just wired the new horns in series using the factory wiring.LOL, I don't know why Mazda did that.
Was it a direct replacement for your factory horn? I'd like to replace the one on my wife's 3.
I think it's a Japanese thing. My Impreza has the worst "pardon me" horn.
This was the best solution to the problem:
http://www.airhornsoftexas.com/emergency-air-horns/1510-kit-emergency-firetruck-air-horn-kit.html
3 Piece Wood Chisel Set - pass
http://www.harborfreight.com/3-piece-wood-chisel-set-66590.html
That's certainly worth a try. Can anyone send me a link to a coupon that works. I went into the store with two 20% coupons that I thought would work. I'd hate to go back to request the price difference with another coupon that doesn't work.
Thanks. Michael
I am a professional woodworker that makes custom furniture, and the three horse dust collector is a gem. I have not seen better performance in units costing three times as much. I have several long complicated runs of tubing and have had no problems in 6 months of 6-8 hour a day work.
It's so nice I'm considering buying a second one a shop expansion I'm planning.
HF 6 ton jack stands: PASS
Flawless performance holding up the front end of a 3/4 ton truck.
700 lbs. Capacity Five Drawer Tool Cart
Item # 95272 Manufacturer: U.S. General PASS!!
it took some time putting it together. dont tighten down any of the bolts until it is all assembled. then sit it level and tighten them down. got it for $149 with coupon.
3 Ton Heavy Duty Floor Jack with Rapid Pump®
Item # 68048 Manufacturer: Pittsburgh Automotive PASS!!
used this to put my motor back in my honda accord. everything worked smoothly. no complaints what so ever. got it for $64 with coupon. i added the 2 year ESP for $19.99
Does anyone have an opinion on specific sets of 1/2" drive metric impact sockets? I want to get a set of both shallow and deep.
anyone here try out the high capacity NiMH batteries that hold their charge? anyone know how they compare to the eneloops from Sanyo? I've been making the move to switch over 100% to rechargeable batteries now that they have a 3yr shelf life... just wondering if the HFT ones are "about as good" as the eneloops? they are cheaper when bought with the 20% coupon than the eneloops @ costco.
I would say the chances of that are zero. Eneloops are some of the best rechargeables I've ever used, very much perform as claimed. Why would HFT have anything better than an average grade of battery if that?
I've never bought a HFT battery, but I know they have them due to returns on the outdoor solar light batteries. Normally that would stop me from making a comment, but batteries are commodity items, wide used and with many users that go through a high volume, really good cheap cells would be widely known.
Tool and service carts are now excluded from the 20% off coupon. Three specific SkUs were mentioned but of course I forgot to write them down...
Pneumatic cutoff tool: utter garbage fail
I've gone back and looked at magazines I have from 2011 and the 20% off coupon excludes tool cabinets back then so they've been excluded for a while.
Anything designed to be struck with a hammer or used with an impact PASS all others FAIL
Tool CARTS is the new wording added to the coupons.
