Non garbage work lights
vibenation
Yea! I soon will have my own garages! Will be moving into a house next weekend that has them just waiting for closing, super excited.
The lighting in the garages ****, but before I can even tackle that I need to fix up / paint / doll up my current townhouse for sale, and to do that I will need some work lights that do not ****.
Over the years I have bought many lights similar to these:
http://www.tractorsupply.com/designer-s-edge-1000-watt-halogen-twin-head-tripod-work-light-3206833
Different brands, different stores, etc and they have all sucked, died, and fell apart.
Does anyone know of a decent alternative that is not prohibitively expensive that I can use to fix up the townhouse, and then have be useful down the road in the new shops and not fall apart after being used twice? I did a google search and did not come up with anything good, and did not find anything here on GJ either.
I am not dead set on halogen, and would consider led or florescent as well, hoping to find the following features:
BRIGHT
Heads can easily be separated from the tripod and wall mounted / adapted to other purpose down the road.
Not cost more than about say 100 bucks.
Looking for quality, anyone have any / seen any?
Danglerb
SoCal
Best cheap option I've seen are some of those aluminum light fixtures with the wire clamps and put 30 watt or so CFL spiral bulb in them.
Greatbear
Columbia/Fulton, MD
I have both a Kobalt and a Husky fluorescent version of the worklight you posted. They have both been decent. I prefer fluorescent over halogen because of the fraction of the heat dissipated, the 500w halogen version I have has scorched flooring and burned me on occasions. The fluorescent versions don't burn out when jostled. The Husky comes with a stand, the Kobalt didn't.
dankicksass
New Jersey
I like the dimmable Craftsman units with the magnesium body. Had a bunch of Cooper fluorescent 65w work lamps and the circuitry in them all went bad, now I keep it simple with halogen only for this sort of lamp. Big fan of fluorescent overhead and task lighting, but for portable illumination nothing really beats old halogens.
Danglerb
SoCal
I figure I'm actually going use a work light for long periods, so I can't get past the 500w per bulb with Halogen. Here in SoCal, thanks to Enron, we pay 26/Kwhr.
NAPA 7825078
I have this one with a 100W florescent bulb and I like it a lot.
Danglerb
SoCal
NAPA 7825078
Are you talking 100 real watts or light equivalent watts? The real 100w CFL bulbs I've seen are like $45 each and mogul based.
The problem I have with a CFL, is if it breaks, its a mess, mercury etc.
OTOH one of my regular use lights is a plastic version with a 25w or so CFL in it, and I just use some care with it.
V
vibenation
Was actually thinking of the tripod mounted lights, and thanks for all the replys. I do plan to eventually sort out some sore of handheld work light, maybe on a reel, but for now it seems like for the cost it is hard to beat the 500w cheapie halogen setups.
W650Mike
North Central Texas
I have a couple of those 500W Dual Halogens on tripods and very rarely use them. The light is harsh, too shadowy, and they generate serious heat. The CF "bulbs" in a number of clamp-on fixtures would be much better in terms of light quality - and not burn up the AC.
Let's see you setup when done!
V
vibenation
Nowhere near ready to show pictures yet, looking more like a warzone than a properly sorted out garage :)
I did get my move done this weekend and ended up running over to Lowes and buying a single clamp light to make sure I did not trip over too many boxes, but went with a flood lamp I will later put in one of the house motion lights down the road. Going to go with a few more clamp lights in the four corners of the garage and will try out the CFL bulb option. Maybe a week or two and then we can talk pictures :)
